Go to Post I NEVER doubt the insanity of pig farmers. - Amanda Morrison [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 25-09-2001, 08:27
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
Lawn Mower Wheels Question....
It seems that many teams have used lawn mower wheels in the past. I can not seem to find any that have a 3/8" bore, only 1/2" bore. How have other teams solved the problem of mounting a 1/2" bore wheel to a 3/8" diameter shaft?
Thanks,
Jim Meyer
Unread 25-09-2001, 20:11
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Official response - Wheels
The wheels are made to fit using bushings. They are located at home depot in the little drawers. Just saw them off to size.
Many local hardware stores have them also. They are usually alum.
Mike Martus
Unread 26-09-2001, 02:32
Mike McIntyre Mike McIntyre is offline
no team (none)
Mike McIntyre is an unknown quantity at this point
If you are mounting a non-driven lawnmower wheel, the scintered brass bushings that were in your kit have an outer diameter of 1/2" and should fit nicely inside the lawnmower wheel; however, if you are using it as a drive wheel, you might want to try bolting the split-tapered bushing to the wheel (there are 2 unused holes) and attaching the sprocket to the bushing in the normal fashion; this is discussed in both the How-to video and the How-to manual. You can even drill holes through the sprocket and attach it directly to the wheel if you want to (it's your sprocket: enjoy!)
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
Q&A Traction Question answer Cory Technical Discussion 4 09-01-2003 06:37
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Question about wheels Randy_Ai Technical Discussion 9 24-01-2002 17:14
