Go to Post It doesn't matter if students get inspiration from planning to creating to manufacturing to purchasing to watching to engineers creating the parts etc etc etc. As long as students are getting Inspired, FIRST is doing it's mission. - David Kelly [more]
Unread 26-05-2008, 21:38
ttldomination's Avatar
ttldomination ttldomination is online now
Sunny
Types of Metal
Hello All,
My team uses 80-20 and like 99% of our robot is 80-20. Now, in the past years we've been heavy and it seems like our metal is heavy 80-20 is strong but we are looking into other options.
I would like to know what kind of metal do you guys use? Besides 80-20.
1648: 2013-2014
5283: 2015
Unread 26-05-2008, 21:41
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Types of Metal
this year since we couldnt afford enough 80/20, we used 3/4 inch square box aluminum and filled it with plastic. worked perfect
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
Re: Types of Metal
ttldomination,
Generally, you can't beat the strength to weight ratio of Mithral. That stuff is tough! Your robot will be able to withstand just about anything you can throw at it (or stab it with).
-ComradeNikolai
I cut myself shaving with Occam's razor.
Unread 26-05-2008, 23:59
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Types of Metal
Originally Posted by ComradeNikolai View Post
ttldomination,
-ComradeNikolai
Yeh, too bad the balrog destroyed the mine
We used 1/8" 1x1 and 1x3 this year (ack, heavy!).
We will most likely switch partially to 1/16".
Kitbot chassis with modifications of course.
-Vivek
"we don't build robots, we build people"
Unread 27-05-2008, 00:08
Aren_Hill's Avatar
Build Nifty Things
Re: Types of Metal
1x1x1/16th box tubing for the entire frame and lots above that. aside from that we use alot of 1x1x1/16th angle, all aluminum of course.
A guy who likes robots.
Unread 27-05-2008, 00:13
Re: Types of Metal
Nah, just the access is blocked. Without the Balrog, it's wide open.
Mithril may, however, fall under the metal type Unobtanium.
Kit frame, or if you like custom, 1" by 1"-2" by 1/8" wall tubing is pretty good for a drive frame. Higher up, 1/16" wall works well. Thing about the drive base is, it takes a beating even with the bumpers, so 1/16" wall might not be the best option. (Then again, properly braced and with a decent material on top, 1/16" can support a robot climbing on top of it, so...)
Unread 27-05-2008, 00:37
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
Re: Types of Metal
I believe we only used 1/8th wall thickness in four pieces of the base frame, those being the four blocks that the axle( a dead axle) for the wheels go through. We did have one incident at Western where we hit the wall and bent our entire frame, but we fixed it, and then glued a solid piece of diamond plate at the weak point to give it a little more structure, without too much weight increase. If we had just incorporated a few triangles into the base in the first place it probably wouldn't have been an issue at all.
I am always doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
--My Life in FIRST--
2009 Detroit Xerox Creativity Award
2009 Detroit District Finalists - Thanks to 1856 and 2620
2009 Kettering District Quarter-Finalists - Thanks to 1504 and 1025.
2008 Kettering Kickoff Champions - Thanks to 67, 1075 & 2619
2008 MARC Finalists - thanks 67 & 226
2008 Great Lakes Finalists - thanks 66 & 217
2008 Western Michigan Semi-Finalists - thanks 2337 and 1504
2008 GLR Judges Award Winner
2007 Curie Division Champions - thanks 330 and 1270
2007 ARC Champions (13 and 0, plus scoring a double-keeper!) - thanks 1625 and 313
2007 MARC Champions - thanks 1732 and 1023
2007 Xerox Creativity Award - Western Michign
2006 I.R.I. Champions - thanks 71 and 1625
Unread 27-05-2008, 01:00
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Types of Metal
3/4"x3/4"x.035" Chromoly Steel (Available at Aircraft Spruce) is wonderful if you can weld (not as tricky as aluminum i don't think).
You can use 1/2"x1/2"x.035" as well for areas under less stress. The stuff is super light, (about the same as aluminum), more compact than 1"x1"x1/8" box aluminum, and three times as strong. Cost is the only downfall but it isn't anything too unrealistic. Teams 269 and 1501 tend to work with this stuff and both come out with VERY solid frames.
ITEM is a similar solution to 80-20. Don't have a source but I've heard it is stronger than 80-20 as well.
Other than that, on 171, we use Kit of Parts frame and 1"x1"x1/8" or 1"x2"x1/8".
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 27-05-2008, 07:38
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Types of Metal
We on 33 have been doing a folded sheet metal chassis for the last few years. Once you learn how to work with sheet, it is pretty easy, very light and very effective. You do need to learn rivet techniques and how to bend metal accurately an effectivele. We use heat treated 6061 T6. Before everyone tells me you can't bend it, that is not true. Heat treated (T6) means you need to be very careful bending it and use an ample radius.
For the big structures we have generally been going with space frame welded aluminum tubing both square and round. I have a lot of race car chassis construction experience so it helps. One of our students did most of the welding this year. While she is not a pro, she gets the job done.
What material you decide to use depends on budget, equipment, and skill sets. 80/20 or Star bar is very easy to use but extremely heavy (from a KB33 perspective). 1/16" is the beefy stuff on our machine and we often go down to 0.035" wall round tube.
If you do not have a skilled welder, I would recommend visiting the Team 1216's website and check out their chassis. The pre-drill 1x1x1/16 box with a very specific hole pattern. This technique gives 90% of the strength of 1x1 box with the flexibility of Star-bar or the kit rails with a TON less weight. These guy are pretty modest and only went to 1 regional so you won't see a lot of buzz about them. As a structures guy, I have a lot of repect for this technique as it has the 4-way threat of strong, lightweight, flexible design, and easy to use/manufacture.
Another good source are the 2 "Behind the Design" books. You can almost tell what line of work the sponsors are in by the construction of the robot. With aircraft companies you will see a lot of sheet metal. Nasa and Robotics related sponsor teams seem to have a lot of CNC. Big 3 teams seem to have a lot of welding.
As far as material sponsors to order from Aircraft Spruce has an awesome selection but can be a bit slow to certain areas. They have some truly amazing materials line a strut material that is 11oz. for 8 feet. Online metals is a good plae to order small quantities, but were extremely slow on their delivery for us (I did find a way to expedite future orders). Mcmaster Carr is fast but expensive.
Unread 27-05-2008, 19:39
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Re: Types of Metal
I was mistaking 80/20 for starbar.
Unread 27-05-2008, 19:42
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Types of Metal
ttldomination,
I sent you a pm. Just get in touch with me and we'll discuss some things.
Mentor 2415
Unread 28-05-2008, 11:20
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Types of Metal
Bleh, the less 80/20 that's used on a bot the lower my blood pressure is. It leaves too much room for last-second decisions that haven't been thought through.
We've used 1/16 wall 1x1" 6061 Aluminum tubing for our frame for 3 years now. It's always been welded. We have students that practice welding on our prototype frames, then they assist the pros who do the welding of the actual frame during build season. From there the frame goes straight to powder-coating at the same sponsor, which also adds strength and rigidity to the frame.
Our drive base frame this year came out to 6.1lbs after powder coating, and had zero CNC work or cheese-holes added to it. In future years we will probably experiment with 1"x1/2" tubing that has a 1/16" wall and sturdy injection foam in order to produce a more compact frame.
GitHub
Unread 28-05-2008, 11:33
cooker52's Avatar
cooker52 cooker52 is offline
Cookie
AKA: Seth Cook
FRC #4272
cooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant future
Send a message via AIM to cooker52
Re: Types of Metal
1501 has used Chromolly tubing on our past two robots. It's light and strong. We gas weld it, but I believe you can use better methods of welding.
I will never be able to leave 1501. Trust me, I did and I came back.
“If you worried about falling off the bike, you’d never get on.” Lance Armstrong
Monocoque, what a beautiful thing.
Unread 31-05-2008, 21:07
Billfred's Avatar
Billfred Billfred is online now
Re: Types of Metal
I did some googling to no avail, since I haven't heard of it before: What is starbar?
Unread 31-05-2008, 21:28
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Types of Metal
We've bought fiberglass pultrusion from Creative Pultrusions. shipping is a bit expensive....
http://www.creativepultrusions.com/
[OCCRA]: Types of metal rdudek OCCRA Q&A 1 20-10-2006 16:01
Gear Types Joe_Widen Technical Discussion 16 02-06-2006 11:46
R/C Control types Andy Brockway Programming 43 24-11-2003 17:07
Types of Drives? indieFan Technical Discussion 50 20-10-2003 12:27
Music types Carolyn Duncan Chit-Chat 42 03-08-2001 23:06
