Go to Post The most important things for a team to take to any competition are a sense of humor, a big bottle of Advil, and a camera! - Rick TYler [more]
Unread 29-05-2008, 20:37
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Belt Drive Pulleys
Hey,
Team 694 was considering building a drive train over the summer, and using belts as opposed to chain to cut down on weight. I have two questions relating to this. First, is it a bad idea to use the nylon pulleys? Are they too weak or will the teeth wear? Second I was wondering how much belt stretches. I know that chain can stretch quite a bit and was wondering if belt does the same. Any teams have experience with this?
Thanks a lot.
Unread 29-05-2008, 20:53
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Belt Drive Pulleys
Originally Posted by Ice Berg View Post
Hey,
Thanks a lot.
Nylon pullys will wear faster than aluminum ones.
Is it a bad idea to use them? For that answer you'll need to calculate the sheer force that your drivetrain will produce and look at the sheer strength of the material. From there you should have a good idea if you have enough safety margin (I usually look for a safety margin of 5x or better due to shock loads)
Belts do stretch a little. You can get belts that have been pre-stretched and ones that have fiber mesh reinforcement (both will limit stretching ... but it will still stretch). I would recomment an idler so that you can adjust the tension as the belt stretchs.
___________________
- Tennyson, Ulysses
Unread 29-05-2008, 21:19
Here is one team's experience with a belt drivetrain: http://www.chiefdelphi.com/forums/sh...ad.php?t=61512
Unread 29-05-2008, 21:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
look at 125's robot too
Unread 30-05-2008, 14:54
DGrohnke1023's Avatar
DGrohnke1023 DGrohnke1023 is offline
Is Looking Backward to Look Forward
AKA: The Dan
FRC #1023 (Bedford Express)
Team Role: Driver
DGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of light
1023 has used cogged belts instead of chains the last 2 years.
Our 2007 robot had aluminium pulleys which we had no problems with. The belts stretched during build season and we retightened the belts (once). The drivetrain did not have to be worked on through 3 competitions it just worked.
The 2008 robot also used belt drive but had some problems. Our original ratio was not right and the belts would slip as we turned; we did not use an idler pulley. Another issue for 2008 was when we used plastic and metal pulleys. They came without a keyway and we had them keyed. We later learned they weren't ment for the stresses we put them under, the plastic seperated from the metal leaving us spinning around the field.
So I would recommend belts as long as the pulleys are metal and the belt is tensioned.
Daniel Grohnke
2009 Bedford Express Captain
2009 - Lansing and Troy Districts, The Championship
2008 - GLR Quarterfinalist & MARC Semifinalist
2007 - GLR & Boilermaker Finalist & MARC Champion
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarterfinalist
2005 - GLR Finalist & Judges Award
2004 - GLR/DTR Semifinalist
2003 - GLR Quarterfinalist & GLR/NAT'L Rookie All Star
Unread 30-05-2008, 19:50
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Two things. The Gates belting supplied in the kit is really good stuff. As long as it is tensioned its tough stuff. You can find it on McMaster Carr or look on their site for a local dealer. Local dealers can often get custom sizes for belting and a much larger selection of ratios. The second is that there are steel lined belts on the market. I don't know of a specific brand that makes them (Goodyear does I think). They have really high tensile strengths and quite adaptable. I've used them in other applications and they worked very well.
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 31-05-2008, 00:33
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
This year we used timing belt in our lifting mechanism. We used polycarbonate pulleys with aluminum hubs. We ended up having to make new, larger hubs after they stripped, but we could have prevented that with some screws through the pulley and into the hub (they were also weakened by machining.)
As far as material, urethane and rubber belts are both very strong and can be purchased with kevlar or fiberglass belting from McMaster-Carr. I've never heard of one breaking in a FIRST robot (not to say it can't happen).
If you're using pulleys/belts, a few things to keep in mind:
1. Find the torque/speed ratings of the belt you're using. Different pitches can take different amounts of torque. You can find this information in The Machinery's Handbook, or probably somewhere on the intertubes.
2. Make sure that your belt is tensioned properly. This can be tricky, especially since it stretches a small amount as it wears in. Adjustable tensioners are useful here.
3. Maximize wrap!!!! Since belt depends more on friction than chain (even timing belt) you want as much wrap as possible.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 02-06-2008, 09:59
Brandon Holley's Avatar
If it is a prototype drivetrain, go for it. You can always go back and switch to chain if you do not like it.
We used belts this year and it worked out great. They are MUCH lighter than chain and sprocket (1/6th of the weight for us) and you can get the belts in the exact lengths you need although you will still need to tension them.
We used Kevlar reinforced belts and found that they did NOT stretch noticeably in any fashion. Our tensioner was a piece of delrin turned down to the correct size, no springs, no adjustments, just the same amount of tension the entire season and we never needed to adjust them.
Belts CAN be done, do the calculations, make sure its right for you, and go for it, like i said, worst case is you go back to chain and sprocket and learn your lesson.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 03-06-2008, 14:25
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Brandon,
Can you tell us what belt and pulley combinations worked well for you? We'd like to take a shot at incorporating them into our drive train.
Belt drive esisso Motors 7 22-01-2008 23:19
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
Timing Belt Drive System maclaren Technical Discussion 31 01-08-2006 10:08
Drive belt Rachika Garcia Rules/Strategy 3 10-01-2006 21:19
belt drive/tank treads dradius Kit & Additional Hardware 14 19-06-2005 23:16
