Help with custom transmision and gear CAD.
I have been trying to design a custom two speed transmission for our robot. I was planning on using the AndyMark Gen1 transmission as a base model, then replacing the gears with 20 degree pressure angle gears so that we can get the reduction that we wanted. My idea was for a 4:1 shift with the highest being around 7:1 and the lowest being 28:1. I have tried experimenting with the spur gear feature in inventor but I am unable to get it to work. Does anyone know of a guide for this or can anyone help? greatly appreciated.
Re: Help with custom transmision and gear CAD.
If you don't like the design accelerator you could always download the i-gear from the FIRST CAD Library. It always worked for me (I <3 i-sprocket). |
One of the first things I do when designing a transmission is similar to you I take a look at the ratios I want to achieve and then make a spread sheet of the available gears and their pitch diameters. Using this info I can play with gear sizes to obtain the desired ratios.
When going to CAD the transmission I recommend not doing the teeth features to start and just making cylinders that have an outside dimension of the pitch diameter. This makes the components much easier to model and will accomplish the goal of having proper geometric alignment, even if it doesn't look as pretty. The other thing you should note about 2 speed transmissions is you need to have enough size on the face of the output gear to have a dog (or any other shifting mechanism) engage the face of the gear. Alot of this has to do with how compact you are trying to make your transmission as it will limit the ranges of your shift. Without doing any calculations I suspect a gearbox that has a 4 to 1 shift will have to be rather large even using 20DP gears just due to the sizes required for the gears so their center to center distances align properly. Typically 2 speed transmissions are more in the range of 2-3 times a shift. So you will have to decide if you need that speed range. If you need any further help, please continue to ask. We all started where you are. Just don't give up we are here to help. |
I typically design using cylinders at PD (as Greg described). I end up changing my gearing approximately 100,000 times during each design process so these approximations make my life way easier.
Once I've finally finished the design and I want to drop in "real life" models I go to www.bostongear.com and use their BostSpec2 service to download the models for the gears I'm using. (We don't typically make our own gears, we just buy Boston Gears and modify them.) Check out www.bostongear.com they have some great stuff. Then again... lately I just use AndyMark products as my base. They are great and easy to mod for our uses. Hope this helps! Regards, John |
AndyMark now has a 4:1 high/low ratio option for their shifters, it's an optional gear set. It works very well once you have the original shifter (Super Shifter, or Gen 1) set up.
Our drive train uses the guts of the Super Shifter but one of our drive module plates is the same as the side plate of the Super Shifter (we CNCed it to match but also hold our wheel and tensioner shafts.) If you are really excited about building your own shifting transmission, that's awesome, and there are plenty of people on this site (myself included) who would be happy to offer feedback and help. However, if you just want a drivetrain that has 28:1 low speed and 7:1 high speed, I'd recommend taking an AndyMark shifter with the optional gear set, and then finishing your ratio with some nice cheap sprockets, which would make it easy to get another 6/7 speed reduction on top of that, so you get 24:1*(7/6) = 28:1. That said, building custom gearboxes is often very rewarding, and I'd say you can't really make a wrong decision going either way. |
be sure to check your math and measurements and use the tools available to you, such as the JVN calc. Happy CADing! |
#8
We built this exact set-up for overdrive with AM parts as Nikhil suggested.
AM SS with 4:1 span and 48:17 output into a 24:22 chain reduction (AM sprockets of course). It works fine on the long breaks, but be advised, it can be expensive from a power consumption standpoint (especially with a skid steer). If you map your floor speed to power and efficiency you'll get the picture. Since I already have the plots I've included them. Last edited by kramarczyk : 19-06-2008 at 17:19. Reason: typo |
#9
A good number of teams used this option on their Shifters last year. Thanks to Mark for making this suggestion. Sincerely, Andy |
| Help with custom circuts | Iceman1330 | Electrical | 7 | 08-02-2008 23:09 |
| Need help with build a custom circuit for the backup battery | midway78224 | Electrical | 7 | 09-01-2008 20:17 |
| help with 06 denso motor cad file | Jim Schaddelee | SolidWorks | 3 | 29-01-2006 22:37 |
| Please help with CAD design | anthony113 | Technical Discussion | 12 | 19-06-2004 12:12 |
| Need help with custom switches | archiver | 2001 | 3 | 24-06-2002 00:35 |
