Go to Post If my counts are correct, during the official matches 141,077 points were scored, and a minimum of 28,746 frisbees were successfully shot into goals. All without a single decapitation, severed limb, or even one porpoise becoming accidentally entangled in the nets. - dlavery [more]
Unread 23-06-2008, 21:51
computerwiz514 computerwiz514 is offline
computerwiz514 is an unknown quantity at this point
Question Help With Line Follower
Can someone please help me with VEX Line Follower Programming. I don't understand it. I would appreciate it allot if someone sends me a code or gives information. Thanks.
Unread 23-06-2008, 22:11
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: Help With Line Follower
The first step in programming anything is figuring out exactly what you want the program to do. Yes, you want to make a robot follow a line, but how will it do that? What kind of sensors does it have?
If you have one sensor that can detect when you are on the line and when you are off of it, the simplest (but not very efficient) method of following the line is to have the robot turn one way until the sensor leaves the line, then have it turn the other way until the sensor detects the line again. There are better ways to do this, however.
Once you figure out what you want to do, then you can start writing code.
Unread 24-06-2008, 11:20
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
There is some explanation of line following and a simple program in the document "Vex for the Technically Challenged" at this link:
http://www.chiefdelphi.com/media/papers/2019
We used EasyCv2, not Pro, but the application should be similar.
The line follower sample program that comes with the Vex Programming Kit uses 3 sensors, which is more complicated than using one. I think it's easier to understand what you're doing if you start with just one sensor, move up to 2, and finally, try all 3.
He is no fool who gives what he cannot keep to gain that which he cannot lose. - Jim Elliot
Unread 24-06-2008, 13:35
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
You can open V2 programs in easyC Pro.
You may also want to check out www.vexforum.com allot of info there.
Line Following with PID CircularLogic Programming 14 14-11-2006 13:15
Vex line follower sensor kit program jbill30 Programming 5 12-05-2006 14:43
line seeking help needed MisterX Programming 13 21-02-2004 19:42
Help wiring Line sensors magical hands Electrical 1 18-02-2004 10:17
