Go to Post Things go wrong; it happens to the best of us. You learn from it and move on. - Waynep [more]
Unread 01-07-2008, 20:41
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Need help with mini motors
Couple questions? How did you use this? Can you press or put any pinions or spur gear on this? Is there any way to use these? We have a lot because teams have given us these and we have about 12 of them.
R.C.
MadTown Robotics Team 1323
Unread 01-07-2008, 20:55
AdamHeard's Avatar
Lead Mentor
Re: Need help with mini motors
If I recall correctly, they have two threaded holes on the face for mounting.
As for a pinion, You can press a gear onto the shaft if it has the right bore size for a press fit. I think that would be just a few thousandths undersize, but I'm no expert in that. You can buy a gear with bore below that and open it up on a lathe, or you can turn a custom one from gear rod.
You could also buy a gear with a hub and set screw with a bore size the same as the shaft. Although set screws are not a good way to mechanically fasten the pinion to the shaft.
As for usage, I've only seen teams use them as a tachometer and I have to see a team power a system with them. I'm sure some have, I just haven't seen it. It's not terrible powerful, so there aren't many applications for it.
Unread 01-07-2008, 23:29
R.C.'s Avatar
i'm sorry i just remembered that banebots has all the small mini motors in a planetary gearbox
R.C.
Unread 02-07-2008, 11:55
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Yes, they do. You can only get the gearboxes with them already in.
They make for good rollers I hear.
-Vivek
EDIT: At 2 dollars a pop, they are pretty cheap.
"we don't build robots, we build people"
Unread 02-07-2008, 22:11
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
We used this little motors for our drive base. They offered plenty of power and made us one of the fastest robots on the field. We never had trouble with them. They're strong enough to pull my car! This little motors really amaze me with their efficiency, strength, and weight. There has never been a better motor in FIRST.
All jokes aside... yea... I'm not sure what use these motors could have. Possibly put a small fan on the end of them to keep something cool? We've never used the large fans they provide in the kit either, nothing ever gets hot enough to need them. We did use a small muffin fan to cool a FP motor down.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 03-07-2008, 00:20
BaneBots with their gearboxes are plenty strong enough for light applications. 330 used a pair in 2007 for ramps. No penalties for expansion, and one case of pulling the ramps up to go block a spoiler.
Unread 03-07-2008, 00:39
AdamHeard's Avatar
Lead Mentor
Those were the 36mm gearboxes with the much more powerful RS-540 motors though.
Unread 03-07-2008, 06:54
RyanN's Avatar
RyanN
Exactly... The applications for these little motors in the real world are limitless, but in the FIRST world, I don't see very much use. These are the motors that can probably be found in a lot of children's toys (not that the big scooter motor cannot be found in children's scooters, and I actually had one of these motors before they came in the kit).
But with what EricH said, the motors on the small BaneBots are very strong. In fact we used this motor for our arm last year (2007). However, we did manage to burn it out a few times when we accidently stalled it in the pit and in the workshop. This year's fork mechanism involved a more complex and intricate system involving a FP motor, its gearbox, a muffin fan, a servo, and the tread that came with our test AM Performance wheel, some aluminum tube, 1/4" aluminum plate, a 10 turn potentiometer and about ten hours or more of work.
What we ended up with was a very nice wench system that worked flawlessly all season.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 03-07-2008, 10:09
vivek16's Avatar
AKA: vivek
I'm telling you, these things look like they would make wicked rollers.
With a reduction to around 800 rpm, they have 190 oz-in of torque and with the 28mm gearbox, they end up at a weight of 5.1 oz with the gearbox!
These would be really useful in a manipulator because of their relatively high power density.
-Vivek
Unread 03-07-2008, 10:36
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
-Vivek
I agree with this point with the caveat that it really depends on the game piece. Sure, you can pick up any game piece using this motor on a roller when you're sitting still. However when you're in motion the roller needs to move at a speed greater than your robot's speed, otherwise the game piece will be kicked away or forced to slide with the bot (which greatly increases your chance to be defended against). Combine that with the needed torque to pick up the game piece of the year and you should see that there are many years where a small intake motor like this just isn't feasible. Use the "Intake Mechanism" tab of JVN's 2008 Design Calculator.
The conclusion I've derived is that with a 20:1 gearbox this motor was ideal enough to pick up the tubes in '07 and 1-2 poof balls at a time in '06 if your bot drove 6ft/sec or less. I agree that they're great power for the small size and weight in these years.
GitHub
Unread 03-07-2008, 11:05
vivek16's Avatar
AKA: vivek
I was contemplating using a 16:1 or 20:1 reduction with a 4" diameter wheel on the end of the shaft as a roller. Our robot moves at 12 fps or so.
With the 16:1 reduction, it is at 1000 rpm or 16.7 rps. 4*Pi=12.5" or one foot. So that is a surface speed of 16 fps easily right?
We have supports under the ball and these rollers on the sides of the ball (near the middle) so it is not like the rollers would be supporting the weight of the ball directly. We pick up off the ground.
All of your points are valid though.
-Vivek
HELP EMERGENCY WITH FISHERPRICE MOTORS Team2441 Motors 5 16-02-2008 22:42
questions on window motors!!!!! need help! nwbutterfly Motors 4 19-01-2005 18:01
Some help with motors Bharat Nain Technical Discussion 2 05-03-2004 19:29
Window Motors. Need help!!!! Mohsin Motors 1 27-02-2004 13:05
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
