Go to Post Spelling mistakes make me sad...Almost as sad as not being able to go to Atlanta this year.. Almost. - Elgin Clock [more]
Unread 03-07-2008, 14:30
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
Pneumatic Muscles: for good or for awesome?
Check these awesome pneumatic actuators out.
Fluidic Muscle is a tensile actuator which mimics natural muscular movement. It consists of a contraction system and appropriate connectors. The contraction system is formed by a pressure-tight length of rubber hose, sheathed in high-strength fibres. The fibres create a rhomboidal pattern with a three-dimensional grid structure. When internal pressure is applied, the hose expands in its peripheral direction, thus creating a tensile force and a contraction motion in the muscle’s longitudinal direction. The usable tensile force is at its maximum at the start of the contraction and then decreases in a virtually linear manner as a function of stroke. An efficient operating range is provided with contractions of up to 15% of the nominal length.
The applications of Fluidic Muscle are
as follows:
– Single-acting actuator
– Pneumatic spring
I wish we could use these things on FIRST robots. They are made by FESTO, which provided some of the pneumatic valves in the kit this year, so I'm not sure if they are legal.
ALSO: check out some of the awesome things they have done with this stuff. Look at the menu items, and be sure to check out the videos!
I just stumbled across a video of "Eric's Arm" and was intrigued, so I decided to share with you guys!
Unread 03-07-2008, 14:53
pacoliketaco's Avatar
pacoliketaco pacoliketaco is offline
Alumni
FRC #1807 (Redbird Robotics)
pacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to behold
Send a message via AIM to pacoliketaco Send a message via Yahoo to pacoliketaco
Re: Pneumatic Muscles: for good or for awesome?
WOW. that is incredible. anyone else think of the movie "I, Robot"?
Pace Nalbone
Carnegie Mellon University
Mechanical Engineering Class of 2013
2009 NYC Winner - 56 and 1796
(2009 Regional Record: 18-0-7 wins/ties/losses)
Unread 03-07-2008, 15:34
Tim Baird's Avatar
Tim Baird Tim Baird is offline
Design Ninja
FRC #0126 (Gael Force)
Tim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond repute
Send a message via AIM to Tim Baird
I've played around with these at work a few times when we've had vendors in trying to sell them to us. They're pricey, but quite awesome.
Tim Baird
FRC Alum and FRC/FLL Volunteer
Project Engineer @ Nypro
History:
Gael Force 126: 1999-2000
WPI 190: 2001-2004
Gael Force 126: 2005-2010
Event Volunteer Only: 2011-Present
Unread 03-07-2008, 16:42
Dolan's Avatar
Dolan Dolan is offline
Dolan
AKA: Andy
FRC #1590 (RAMBOTS)
Dolan will become famous soon enough
Send a message via AIM to Dolan Send a message via MSN to Dolan Send a message via Yahoo to Dolan
That is awesome but I don`t think First will let us use them they look like they cost alot.
Unread 05-07-2008, 13:24
spinmunky's Avatar
spinmunky spinmunky is offline
Mechanical/Photographer/Photoshoper
AKA: LJ (Little John)
FRC #0100 (The Wildhats)
Team Role: Driver
spinmunky will become famous soon enough
Send a message via AIM to spinmunky Send a message via MSN to spinmunky Send a message via Yahoo to spinmunky
The Shadow Robot Company has been using these for a while.
http://www.shadowrobot.com/airmuscles/
They also made a hand that does eerily look like one from "I Robot"
http://www.shadowrobot.com/hand/overview.shtml
Videos of the hand in action:
http://www.shadowrobot.com/hand/videos.shtml
"FIRST is like the WWF, but for smart people" -George Herbert Walker Bush
Unread 14-07-2008, 21:14
Lancer Robotics Lancer Robotics is offline
FRC #2437 (Lancer Robotics)
Lancer Robotics is a glorious beacon of lightLancer Robotics is a glorious beacon of lightLancer Robotics is a glorious beacon of lightLancer Robotics is a glorious beacon of lightLancer Robotics is a glorious beacon of light
these are also called air muscles. there is a company in the UK that makes them with less fancy ends. you can even make them with tubing and mesh. Homemade ones tend to rupture easily. some work with less than 60 psi which would be within safety standards but not on the "must use from supplier" rule. Maybe we could get that rule modified?
Unread 23-07-2008, 13:41
Dick Linn's Avatar
no team (Synergy)
Here's an article about making your own "air muscles".
http://www.imagesco.com/articles/air...ription01.html
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Pneumatic Pressure Switch for EasyC Wompas Programming 5 01-02-2007 09:05
pneumatic actuator for storage tank aksimhal Pneumatics 3 13-01-2007 23:19
Awesome website for off season side project antics. Cool projects too. Elgin Clock General Forum 7 07-07-2006 12:54
FIRST -- good for mind, but not for ears archiver 1999 7 23-06-2002 22:14
Punk covers - awesome or ruining good music? DanL Chit-Chat 19 12-05-2002 14:39
