Go to Post Start simple and build up. - Mark McLeod [more]
Unread 09-07-2008, 20:17
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Tips on buying *stuff* in FIRST
Well,
I wasn't sure where to put this thread or if one like it exists (didn't see one) but I am sure everyone has a few tips on buying stuff in FIRST.
I'll start.
When you are buying tube stock, bar stock, or rod, it is often cheaper to get large uncut sections.
For example, I was looking to buy some 3/8" hex shaft and I needed 6". I hit the wrong drop down tab and clicked 6' instead. It was around 7 dollars. I corrected my mistake and it was still like 6.25 dollars! Thinking it was a mistake, I checked the price for 1/16 of an inch and sure enough, it was still 6 dollars. Turns out, they charge 6 dollars for cutting the metal so I can save significantly by just purchasing a 12' section of the material (this way I have enough for many years to come and it is only 7.25 because it is unaltered by the supplier).
If purchasing sheets of some material (rubber, plastic/lexan, or metal), the above trick works. If buying thick(er) sheet metal such as 1/4" aluminum, look into flat bars of it instead of having them cut from a plate. For example, I can buy 1/4x6x15" bar for 17.5 dollars where the same with sheet metal would be higher (for my supplier anyway. It seems they charge 6 dollars to cut for bar stock and 10 to cut plate.)
Also, if buying from the same company, try to get your whole order shipped together to make it cheaper. This is especially true if you have lighter parts (like pneumatic fittings) where the weight is not much of an issue in shipping.
hope it helps, Vivek
"we don't build robots, we build people"
Unread 09-07-2008, 20:59
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Tips on buying *stuff* in FIRST
Also look into shipping costs of both approaches...often the bulk piece will be oversize (or freight) shipping, while a small piece can be shipped UPS for under $10.
If you are fortunate enough to have a well stocked metal supplier in town, this isn't so much of an issue.
Unread 09-07-2008, 21:14
Tim Baird's Avatar
Tim Baird Tim Baird is offline
Design Ninja
FRC #0126 (Gael Force)
Tim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond repute
Send a message via AIM to Tim Baird
When you're going to buy materials and components, it often helps to call in and talk to an actual person. While you're asking for quotes and placing your order, tell them about who you represent and what you're buying this for. A lot of companies will donate materials or give you a nice discount to help you out.
And if they don't, you're left with MSRP and you didn't lose anything anyways. Can't hurt.
Tim Baird
FRC Alum and FRC/FLL Volunteer
Project Engineer @ Nypro
History:
Gael Force 126: 1999-2000
WPI 190: 2001-2004
Gael Force 126: 2005-2010
Event Volunteer Only: 2011-Present
AdamHeard's Avatar
Lead Mentor
From my experience with a large supplier (Coast Aluminum) the more you order, the better price you will get (buying 20 pieces of 10ft extrusion vs. 1 piece) and after a point they will even give free delivery.
Unread 09-07-2008, 22:34
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Whenever ordering from McMaster I always call instead of doing it online.
This allows me to figure out what kind of shipping I need to get something to me by a given time, as well as letting me specify a shipper (for instance, California Overnight will deliver a package shipped by 7 PM the previous night by 10 AM the next morning, for a fraction of the cost of UPS or FedEx). Most of the time I get next day arrival via standard ground shipping.
Seconded on the metal. I never buy in less than stock lengths (12' for solids, 20' for tubing and extrusions) unless it's a very big solid (needed some 3.25" OD 6061 round stock, and some 4"x4" 6061 barstock. Something like $550 for 12' of the former, and $750 for 12' of the latter). If you're buying tubing, extrusion, or smaller solids, they're going to charge you the full price of the length for a cut section, or charge you $20+ to make a cut. A good sales person will tell you if it's cheaper to buy the whole length even if you need the shorter piece.
Don't buy 6061 from McMaster. It's WAY overpriced. I can get the same stuff from Coast for 50-75% the price of McMaster. McMaster's prices on 7075 however, are not bad. Don't buy bearings from McMaster either. We paid 1/10 the price from a local source. Call Motion Industries or a similar company and ask them to quote you the cheapest bearings their suppliers have.
2001-2004: Team 100
2006-Present: Team 254
Unread 09-07-2008, 22:48
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
we used some 3.5" AL for our wheels in 2008. when we called to get a price on the bar stock it was quite pricey, i asked for small drops and they had several hundred pieces about 2.5" long, we only needed about 1.75' long, so we picked up 30 of them, they were less than $2 each and now we have enough for future use.
mike d
See Ya
Unread 09-07-2008, 23:10
run the trap!!!
Team Role: Human Player
ALWAYS deliver parts to a personal residence rather than the school. Some schools don't receive boxes/mail on the weekends.
Its always frustrating to do nothing all weekend and then receive all the parts on Monday
-Philip J. Fry
Unread 09-07-2008, 23:45
MrForbes's Avatar
AKA: Jim
Delivery address might depend on how the parts are paid for, though! For example, anything purchased by our school with a PO needs to be shipped to the district receiving office.
Unread 10-07-2008, 09:00
Dick Linn's Avatar
no team (Synergy)
If you can use some of the sizes of these surplus aluminum jig plate, they are a bargain:
http://www.sandsmachine.com/alumweb.htm
Local metal suppliers usually have a pile of "dings and drops" or "shorts" and may give you a good deal on some of that. At least you may get the quantity price on regular stuff if they know you are a FIRST team.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 10-07-2008, 12:25
vivek16's Avatar
AKA: vivek
Ok, the main supplier we use is discountsteel.com
They have a local warehouse that is close enough that we can just go pick it up. Their metal prices are from two years ago (online anyways) so you will save a little if you order online and go pick it up yourself. I think they have warehouses in Minneapolis, MN and Fortsworth, TX
thanks, Vivek
Last edited by vivek16 : 10-07-2008 at 12:59. Reason: my grammer is not so good early in the morning
Unread 10-07-2008, 12:53
JudyVandy JudyVandy is offline
FRC #0084 (Chuck 84)
JudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud ofJudyVandy has much to be proud of
Rankin Automation in Broomhall, PA, gives FIRST teams a really nice discount on 80/20. We found them really nice to deal with, too.
Unread 09-07-2008, 21:16
vivek16's Avatar
AKA: vivek
Ah, thanks for bringing that up, we have a metal supplier in town so we hardly ever pay for the shipping of metal.
paper: FIRST Publicity Tips Mark McLeod Extra Discussion 0 19-05-2006 10:01
Free Stuff @ First Elgin Clock General Forum 19 21-06-2003 11:06
Taking pics at FIRST events... Tips needed MattK General Forum 17 10-03-2003 22:33
