pic: drive base idea
Re: pic: drive base idea
I am guessing by the looks this will be 2WD right?
Also, will your actual frame material be 80/20? This would definitely be a good base to use that with. How thick plate do you plan to use for the bearing mounts for the front and rear wheels? |
Well... it doesn't necessarily have to be 2WD. The front and back wheels could just be on dead axels. I thought of a chassis and drive train that work like that, as well.
Dead Axles? Never heard of that before...
If it is going to be a two wheel drive, may I suggest you use omni wheels on the corner wheels. This will improve your maneuverability greatly and prevent that skip the robot has everytime you turn. It's looking pretty good. When do you think you will be having more of it done? |
That's cool DB, i was thinking about what it would be like if we turned the center wheel drive we had upside down. And what center wheels are those, they don't look like what we have?
But aren't they cheaper and don't they turn easier than omis??? But then again, we can always use something with more quality.
#8
Hi, I was wondering for a 2wd with six wheels can you lower the two centre wheels as you do with six wheel drives and is this anymore effective than omni wheels (or improvised ones).
Tim |
#9
I'd also suggest powering more than two wheels. |
#10
Although the normal KOP chassis is setup this way, I would avoid using the current configuration. A corner hit on the chassis can easily warp the frame out of alignment. Adding crossbars (making an X in the middle of the frame) or using round tubing instead of square tubing linking the left and right sides will greatly strengthen your frame. Of course, you will have an upper frame and bumpers to help out, but with a little effort, this could save you a lot of time at competition.
We have been using a square outer rail and middle round tubing for the past 4 years, and we've never had a frame issue. It was well abused at IRI and it only came back home with some small dents. Round tubing is structurally stronger than squared tubing, and you cannot torque it very much without breaking a weld. Before everyone says that the KOP frame is very tough, I want to say that this is my personal opinion and I do not want to discourage the use of the KOP frame. I personally like custom frames with round tubing. Auto manufactures use it for a reason, and so do many teams. I would love to hear some input on this as well. For the wheel setup... If you drop the center wheel about 1/8th of an inch, you shouldn't need omni wheels on the outer corners. We've never had issues turning. Actually this year it turned too much. As for the dead axles... I assume you mean that the axles don't spin, but you have a sprocket bolted to the wheel that spin on the axle. If that is so, we did exactly that this year and didn't have any issues... actually, we have done this for the past 4 years. Our base design has stayed mostly the same with improvements each year. This year we identified a problem with using roll pins, and having them shear, so we're probably going to use larger ones next year or come up with a better way to attach the wheel to the shaft. We're also looking into stronger chain. We were pushing the limits of the #25 chain. Last edited by RyanN : 25-07-2008 at 00:58. |
#11
What 1519 has done in the past is cut vacuum tube and zip-tie it to the corner wheels. They still get a bit of forward traction, but it greatly reduces the side scrub. |
#12
Maybe not on all 4 corners though. Some teams have had problems in the past (us, for example) with controlling our robot by having a six wheel drive with 4 omni's. 2 omni's would probably be ideal, either on the front or in opposite corners. I'd also suggest powering at least the rear part of your drive, throw a sprocket and chain on that bad boy and you'd be good to go.
#13
As the drove over the bump it lifted the inside drive wheel off the ground and the machine then swerved directly into the wall. From the stands it looked like poor driving. In reality it was just a little vehicle dynamics issue. I have another thread going on 6WD dynamics. There is a good link to a paper that explains making your robot turn. My recommendation would be power to at least 4 wheels or have your powered wheels at 1 end of the chassis. This brings a whole new set of dynamics issues though (whip oversteer). |
#14
Thanks to everyone for their comments.
Somehow the description didn't get posted when i uploaded the picture. What you see weighs 19 lbs. I haven't decided what gearboxes to use, but i have AM toughboxes or DeWalts in mind. The frame is 1x1x3/16 square tube, and will be welded. Quote:
I was not planning on using 80-20 because it would make it heavier than i want this design to be. The angle aluminum that supports the axles is 3/16 inch thick. Quote:
I will probably continue CAD of this design and similar ones until 2009. I don't know when i'll be 'done'. To answer the comments about 6wd vs 2wd: This drive base design was meant to be simple and light. Part of meeting this goal meant not powering the corner wheels. For 3 out of the past 4 years, 1519 has used a 2wd drive, powering the center wheels only. ![]() We have had good success with this design. The only drawback of this drive system is, like IKE points out, it cant climb ramps. I like 6wd, but this design is meant to be the simple, light, stick-with-what-we-know design. Quote:
Ryan, thanks for your advice about torquing the frame. Where would you recommend putting the round tube? Comments are welcome DB |
| pic: DeWalt drive base | dbell | Extra Discussion | 16 | 18-09-2007 17:10 |
| pic: 114 drive base CAD | CraigHickman | Extra Discussion | 4 | 15-12-2006 00:31 |
| pic: 195 Drive Base | Tom Bottiglieri | Robot Showcase | 24 | 16-02-2006 12:50 |
| pic: 254 completed drive base | CD47-Bot | Robot Showcase | 1 | 26-02-2004 16:34 |
| pic: 1083 drive base | CD47-Bot | Robot Showcase | 11 | 24-02-2004 14:04 |
