Go to Post Have no fear, ancient and brilliant coaches of yore were consulted. - JamesCH95 [more]
Unread 14-08-2008, 16:09
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Arbor Press
Our team is looking for an arbor press to key steel and to pressfit bearings. What ton press would work well for these applications.
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 14-08-2008, 16:59
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Arbor Press
Whatever you do, don't get a hydraulic one. They are way too sloppy.
Lever operated 1-2 ton will do from what I have heard.
"we don't build robots, we build people"
Unread 14-08-2008, 17:04
Re: Arbor Press
See this thread (you could have found it easily yourself by searching the forums before posting).
Unread 14-08-2008, 17:27
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Arbor Press
Arbor Press?? We always used the chuck on our drill press
Good luck finding what you need!
Jacob
Unread 14-08-2008, 17:36
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Re: Arbor Press
Jacob
I actually sugested that to my team
Unread 14-08-2008, 21:53
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Re: Arbor Press
Can bend your chuck, trust me all of our holes since 2006 have been slightly crooked.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 14-08-2008, 21:55
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Arbor Press
Broaching with a drill press, milll, etc, is a very bad idea.
While it may be acceptable for small keways, you can brinnell the spindle bearings, which basically means you indented the race of the bearing with one or more of the balls. This will ruin your tool.
Arbor presses are so cheap ($100-200) that it's not worth destroying a machine using it for something it wasn't intended for. Especially given how often an arbor press is used.
2001-2004: Team 100
2006-Present: Team 254
Unread 14-08-2008, 22:43
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: Arbor Press
We made a few broaches this year with a standard 4" vise, however it was not easy since the part was only supported on one side. We were able to broach Delrin and 1/4" aluminum, but we couldn't keep everything aligned due to the greater forces when we tried to broach a steel sprocket.
We tried using our drill press to get the pinion off the fisher price motor, which did nothing but wear out our drill press. I'm really hoping we can get an arbor press for next year.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 14-08-2008, 22:51
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Arbor Press
I think this might be your best bet if you can't get something surplus or local http://www.northerntool.com/webapp/w...70_20674_20674
Unread 14-08-2008, 23:41
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is online now
FRC #0456 (Siege Robotics)
Re: Arbor Press
When selecting an arbor press keep in mind what your likely uses for it will be. Broaching small keyways and pressing bearings is one thing, broaching 3/8” or ½” hex bores is another. Pressing bearings or cutting 1/16” or 1/8” keyways can probably be done with a 2 ton or even 1 ton arbor press but if you think you might ever want to cut those 3/8” or ½” hex bores in a hub or gear or something consider that a standard 3/8” hex broach is about 8.5” long and a standard ½” hex broach is about 12” long. In my opinion, a 3 ton arbor press is a better option because they usually can handle a 12” long ½” hex broach.
First the good news, as luck would have it Enco has single lever 3 ton arbor press on sale for $69.95 (item 805-1030, regular price $81.10). It has an over the table capacity of 12.5 inches which is probably just enough to squeeze that 12” long ½” hex broach in there while it is inserted in that ½” thick spur gear. Now the bad news, it weighs 160 lbs so shipping is going to be via truck freight and you will need a fork lift to move it around when you get it! Shipping isn’t going to be cheap either!
If you can spare a little extra funds I would highly recommend going with a 3 ton ratcheting arbor press instead of just a manual single lever type. Enco has one for $143.95 (item 805-1035)with a 12 5/8” max work height but again it weighs 148 lbs so shipping is probably going to be as much as the press.
Unread 14-08-2008, 17:39
AdamHeard's Avatar
Lead Mentor
Re: Arbor Press
Jacob
I've been told that is very bad for the bearings in the drill press.
Unread 14-08-2008, 19:10
run the trap!!!
Team Role: Human Player
Re: Arbor Press
I think that depends on what your broaching... After all, the drill has to push a bit through metal.
I do this all the time with small broaches (like 1/16" and 1/8" keyways).
I also have a 20 ton hydralic press which (like others have said) is really sloppy and a pain in the a** to use. But if you ever need to bend/press really big things, it comes in handy
I hear Harbor Freight is a great place to find these kinds of tools. cough...other threads... cough
-Philip J. Fry
NEW TEAM - Pioneer HS Team 1015 in Ann Arbor MI Needs Mentors kmcclary General Forum 17 10-04-2012 08:22
New Teams forming in Ann Arbor, MI - YOUR HELP NEEDED! kmcclary General Forum 5 09-09-2008 18:21
Need Help: FIRST Demos in Ann Arbor 8/9 & 8/11 Jim Zondag General Forum 0 06-08-2008 17:34
Arbor Press Specifications JesseK Technical Discussion 7 24-06-2008 15:10
Ann Arbor Area? David66 Chit-Chat 2 02-03-2004 13:49
