Go to Post Please search before you post (it's fun and free!) - Billfred [more]
Unread 15-08-2008, 21:52
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Wiring help and connectors
Hello guys,
I was wondering if we were still going to be using 12 gauge wire with the new controller. Also does anyone know where to get the battery connector 968 (RAWC) used in the previous season. A link would be very helpful, thanks y'all.
R.C.
MadTown Robotics Team 1323
Unread 15-08-2008, 22:22
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Wiring help and connectors
As far as I know, there has been no official word on wire type. However, since we will be using the same voltage battery, same current breakers, and same (or similar) motors, I would imagine that there would be no need to change this.
Unread 15-08-2008, 22:26
R.C.'s Avatar
Ok thanks, only reason i was asking because we're about to buy about three hundred bucks worth of high strand silicon wire. I really need the info about the battery connector or does anyone else have a good connector for the battery besides the kop ones.
R.C.
Unread 15-08-2008, 22:38
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
If you mean the Anderson quick disconnect connector, it's the only connector you can legally use on your robot (subject to the unreleased 2009 rules, of course).
If you mean the end that connects to the battery, just get some 6 gauge ring terminals from McMaster (7113K446).
2001-2004: Team 100
2006-Present: Team 254
Unread 15-08-2008, 22:49
Joe G.'s Avatar
AKA: Josepher
Here's a link for the Anderson quick disconnect connectors, should you need extras:
http://www.robotcombat.com/products/0C-PP175.html
Unread 16-08-2008, 00:01
Hello guys,
RC, do you mean the battery cable, then that is #6 minimum. You can use something larger, some teams use #4. However there is not much improvement if you keep the wire length short.
#12 has been allowed in the past for circuits protected by a 40 amp breaker but the loss is significant. I recommend #10 for these higher current loads. At 100 amps a #10 drops 0.1 volts/ft. while #12 drops 0.16 volts/ft. (measure both red and black wires please.)
Unread 17-08-2008, 02:27
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
On our battery cables we use what I believe to be the Metra GHDRT4 Heavy Duty ring terminals. We might have a slightly different model with smaller hole size, not sure.
The wire we use is an ultra- high-strand-count super flexible 4ga car audio power wire we obtain locally.
Unread 17-08-2008, 15:51
R.C.'s Avatar
Yes, that is what i am talking about. Do you have any link to it online somewhere. It would help us soooo much. Thanks in advance. BTW:
http://www.audiooutfitter.com/ghdrt4/metra/p135074.html
is this the size for the whole
R.C.
Unread 17-08-2008, 18:23
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Keep in mind that rules change year to year and something legal last year may not be legal this year. Or they may say we cant use one particular type of connector or we must use a connector. Save your money and buy it after we find out the rules of the game.
-Mike
Need help Programming and wiring camera! Amisca Programming 1 14-02-2006 18:37
need some help with the OI, and wiring a display pryoplasm Control System 8 10-03-2004 20:46
Slip connectors (custom electrical connectors) Damian Manda Electrical 2 08-02-2003 17:53
Diagrams for wiring of 15 and 25 pin connectors archiver 2000 2 23-06-2002 23:03
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
