Bumper bracket and weight considerations
If I design and employ a bracket for attaching bumpers to my robot such that the bracket is always attached to the bumper, is that bracket then considered part of the weight of the bumper?
i.e. you remove the bumpers by removing the bracket. |
Re: Bumper bracket and weight considerations
According to which year's rules?
By 2008 rules, I would say that it would count with the bumper, assuming the attachment method was legal. |
Assuming the most current rule set.
I agree, I think the bracket goes with the bumpers. |
That is how we did bumpers this year... the bracket stayed with the bumper and was weighed as part of the 15 lbm allowance.
Now if somone would only come up with a universal bumper bracket. ![]() |
Why do you need to design a bracket?
We just mounted clevis pins on the wood backing on the bumpers and ran the clevis pins inside, through the chassis and captured them using quick release pins. We've been able to attach and detach our bumpers in under a minute the past couple of seasons. |
The only problem with the clevis pin method is if an inspector takes the "bolt and nut system" rule literally (which they probably should).
Chassis design can incorporate bumper attaching points, if you plan ahead. |
#7
I wish the bumper rules were changed a little bit to allow methods of retaining the bumpers that are strong and quick to be released, yet are not strictly bolt and nut interfaces. |
#8
However, I have also seen some quick-release bumper mounts that were not-so-elegant, nor very robust. Teams that built them were better served by changing to the standard mounting method shown in the rules. IMO it will be a challenge for FIRST to write a new standard bumper rule that allows cleverness in the mounting scheme, while preserving safety, robustness, and fairness. The worst kind of specification is "I'll know it when I see it" (IKIWISI). I'd rather enforce a rule that is clear, even if it disallows some solutions that I think are cool. |
#9
The other problem is that many inspectors are not calling teams on it. We spent a lot of time (wasted a lot of time, really) making sure our bumpers would be legal. We would have very much liked to use a quick release pin, but decided it did not meet the letter of the rules. Once we got to the events we saw many teams who had used non bolt-nut fasteners, and were never told to change their bumper configuration.
#10
what's even worse is when you have a setup, and told from regional to regional that its legal, its not legal, and then its legal again (in terms of where the fasteners weight count towards).
We had different interpretations on whether the nut/bolt fastener counted either towards the weight of the bumpers or the robot which in situations caused us to not meet the 120 and or 15lb requirements. The whole issue of using bumpers is to protect bots and some inspectors focus more on the wording than the purpose of having them mounted to your bot. As just mentioned, I hope the rule(s) are revised. It was a pain taking the bumpers on and off. Thanks for the idea on the clevis pin. If its allowed next year, we may try that. |
#11
I wish we could go back to making bumpers optional. While there are many advantages to having them I can think of just as many not to have them. I wish it was a choice instead of a requirement, then people could attach them legally or not at all and still be fine.
#12
Many teams are capable of choosing to not use bumpers, and as a consequence building a robot that has to withstand an impact with another nonbumpered robot. |
#13
Everyone,
I can tell you that there has been a lot of discussion over the bumper design and rules. We all have to wait until the robot manual is released to know for sure if there is any change. The rule on bumper design should make all bumpers fairly alike but I can tell you, I saw almost as many bumper designs as I saw robots in the years since the bumper rule was included. As other have pointed out, R08 stated "STANDARD BUMPERS must be attached to the ROBOT with a boltand- fastener system to form a rigid, robust connection to the ROBOT structure (i.e. not attached with Velcro!)." |
#14
We've used bumper-side brackets these past two years and used tent stakes to install/uninstall them.
2006: Side bumper mounts were FDM, front mounts sheet aluminum, rear mounts plate aluminum 2007 (bad year for us): FDM brackets all the way around 2008 (good year for us): FDM with bracket mating areas built in to the unibody. -q |
#15
This discussion misses the point-the bumpers!!!
Who cares how they are mounted as long as it is safe and there is no unfair advantage? Consider this more- if you built the bumpers exactly to the specs in the rule book last year they could not make the specified weight. This is a VERY sore subject since I spent most of a day dealing with a x**&*^ inspector at Nationals who seemed to think there is only one right way to do things. Apparently the rumors of the CD community weigh a lot with some inspectors over others. Sometimes enforcing the spirit of the rule book is more important than enforcing the letter of it. Mark these words- the day is coming when all FIRST robots will be clones of each other with little or no freedom for individual innovation of design. Lets hope that this year's game will encourage a diverse array of innovative designs and materials uses. Otherwise we might as well eliminate the Xerox Creativity Award. WC (yeah- this ticks me off) |
| **FIRST EMAIL**/Pre-Order Lunch and Airline Considerations | Mark McLeod | FIRST E-Mail Blast Archive | 0 | 07-04-2008 18:02 |
| Making Bumper Weight? | Ian Curtis | General Forum | 28 | 17-02-2008 09:34 |
| pic: Bumper and me | lilac | Extra Discussion | 7 | 09-01-2008 16:22 |
| bumper weight | chippermonky | Technical Discussion | 10 | 09-02-2007 14:42 |
| Rookie Workshop Mechanical Considerations Presentation | ahecht | Technical Discussion | 0 | 07-01-2006 01:06 |
