Labview 8.5.1 Now available for download
I'm not sure if it's been widely or clearly anounced, but...
You can now download and install the LabVIEW 8.5.1 environment with an extended trial license good til Jan 15 2010 if you want to follow allong with the beta testers here at the following link. http://www.usfirst.org/community/frc....aspx?id=10934 The instruction on this page are fairly "beta" though. Use this sequence (you'll be happier ![]() 1.Using "Save Target As..." save the file 'LabVIEW_FRC_PKG_080501.lic.txt' to your computer. 2. Rename it to 'LabVIEW_FRC_PKG_080501.lic' "lose the .txt extension" 3.Download and install LabVIEW 8.5.1 from one of the following: o FTP: ftp://ftp.ni.com/pub/frc/lv851.zip o HTTP: http://labview8.ni.com/pub/frc/lv851.zip (after part 61 the drivers just click later to finish) 4. Put the license file 'LabVIEW_FRC_PKG_080501.lic' in the following folder on your computer: C:\Program Files\National Instruments\Shared\License Manager\Licenses 5. Using NI License Manager > Activate the software with this serial number: L12R86754 6. Optional??? Using NI License Manager > Turn on the License Server Most products do not require the Local License Server. The controls for this feature remain hidden unless you have applicable products installed, such as LabVIEW Remote Panel Connections. (WE have this RPC but for ????) |
Re: Labview 8.5.1 Now available for download
Is this version just for Windows, or is it also Mac/Linux compatible? (I'd check myself, but at the current rate, it will be another 6 hours before my download finishes.)
David |
Just looked in the setup.ini and its only for Windows
VersionNTMin=5,0,2195,3,0 |
This was sent out in an email blast to all teams. See more discussion here: http://www.chiefdelphi.com/forums/sh...threadid=69597
Hopefully this will get a wider audience than the email blasts.
Which I missed. |
I do find it interesting that they are releasing this in what amounts to a public license. I wonder how NI feels about this.
#7
I wouldn't even begin to use the term "public license" to describe this distribution.
If you check the acknowledgement email you'd see clearly that they know who is using and on what computer they are using it on. This is clearly a time limited highly specific version of LabView with the purpose of broadening the opportunity to learn "How To". To Quote the email The activation code(s) above were generated with the following serial number and for the following computer: Serial Number: L12R86754 Computer ID: XXXX-XXXX-XXXX-XXXX This serial number has been used to generate activation codes for FIRST Robotic Competition on 67 different computers in the past 365 days. |
#8
Erm. Since you could easily enter a fake name and organization, and do this through a TOR node or some public network, there's effectively zero practical restriction on who can use this license. We're not talking about people doing this legally, after all.
Granted, obtaining an illicit copy of Labview or most other software isn't particularly difficult for the moderately technically savvy and moral deprived. This is just making it that little bit easier, which is confusing when NI has gone to all the trouble of having the authorization system in the first place. As a counter example, Autodesk has just as strong an authorization system and still manages to give the teams free software without putting a public download link, license, and serial number on FIRST's website. It might be that this is simply because of the rush to get the software to teams ASAP, and following years will have a more secure distribution model, but it's still mighty confusing. |
#9
And don't get me started on Autodesk Firstbase. |
#10
How would they know that?
#11
I'm assuming the computer ID is some hash-value that is generated based on that particular computer's configuration, similar to how other companies like Microsoft do it.
They probably keep information like IP address tied to the computer ID as well. Afterall, there's no reason they can't simply shutdown that license number right after the ship of our actual copies of labview, so I doubt they're too worried about it. |
#12
If that is so, it implies that we need an internet connection, not only to install LabVIEW, but to run it. Is that truly the case? I'm just now copying the lv851.zip file to a CD so I can install it on the computer at our workshop. I had already been fretting that instead of carrying the data to the computer, I might need to carry the computer to the data. Now I'm getting worried that I might not be able to use the computer at the shop even after putting the software on it.
#13
I believe Tom was speculating about how it could work, not stating facts about how it does. |
#14
As far as I can tell (good or bad) there really isn't any possible way for NI to control this distribution. 1) How to get it and the serial number to use are on a web site that anyone can see. 2) The serial number and installation is the same for everyone and there appears to be no limit to the number of computer (seats) that it will install on. 3) There are multiple ways to get the required license codes to use it for the licensed period (til January of 2010) including direct internet connection, email from a separate machine, and even just calling up NI over the phone. 4) On the two machines I have installed it on - my laptop with an internet connection and our donated team desktop without and internet connection getting the activation code was a simple automated process. I just asked a machine to give it to me and it did (in a matter of seconds). No human @ NI was involved, thus no verification for FIRST team only use or not. I assume they don't care if this is out there for everyone because: 1) Even though it is the "Full Version" of LabView it seems to be a FIRST specific distribution. 2) It will shut itself off in a little over a year. 3) If someone outside of FIRST gets it and learns it and then starts using it and then gets dependent on it they are going to be out of luck in a year and will be forced to buy it. 4) It is version 8.5.1 and the latest version seems to be 8.6. I assume we will be getting 8.6 in a box with actual CDs in the KoP in January. Last edited by ChuckDickerson : 16-10-2008 at 17:17. |
| **FIRST EMAIL**/FRC Competition Manual Encrypted Sections Now Available for Download! | Rosiebotboss | FIRST E-Mail Blast Archive | 26 | 05-01-2008 12:09 |
| 2005 Field 3D Model- Available For Download | Alexander McGee | 3D Animation and Competition | 10 | 08-02-2005 11:45 |
| Videos available for download | MrToast | General Forum | 22 | 09-01-2005 15:00 |
| Q&A Watcher Available for Download | Nate Smith | General Forum | 11 | 19-12-2002 11:12 |
| Custom Dashboard code for LabVIEW ready for download. | archiver | 2001 | 3 | 24-06-2002 00:49 |
