pic: 4 Speed CIM Gearbox
Re: pic: 4 Speed CIM Gearbox
I'll refrain from the usual "4 speed is unnessecary bla bla bla" as you don't seem adamant about using it for season.
In the context of designing a 4 speed, it looks good. Pretty simple, pretty clean, and if that weight is with CIMs (which I think it is) and witch the correct weight set for the CIMs (2.75lbs), it's not that heavy. |
You could lighten those plates up a bit more. If you want me to cheese them up, give me a pm. http://www.chiefdelphi.com/forums/sh...ad.php?t=68968 is a link with an example of the type of cheesing I'm talking about.
It looks good. -Vivek |
Similar to what 968 did in 2004 and 2005 but theirs used a chain to link the two segments instead of gears.
Looks good. ![]() Last edited by sanddrag : 02-11-2008 at 21:06. |
AM Gears? Very Nice Job on the Cad, lighten the plates out like Vivek said. Also, see how much weight you could lose using AM aluminum gears and circular lightening pattern.
Also, aluminum gears may not be strong enough in this application; it's something he would need to calculate to know for sure. A lightening pattern in the gears would be a good idea as well. |
#7
Hmmm, never thought about that, THE RAWC uses 1/4" Delrin I think.
#8
Another thing, would it work to replace some of the gears with brass? I heard that brass gears are supposed to work in, providing a better mesh. I am thinking of replacing most of the gears with aluminum/brass if that will work. |
#9
Aluminum gears can be quite successful if done properly. It is A LOT of work though, and requires a very specialized and dedicated sponsor shop. The 968/254 gearbox from 2007 is a fine example. Read about it here. |
| pic: 114 2 speed Gearbox | CraigHickman | Technical Discussion | 13 | 25-02-2007 19:41 |
| pic: Version 2 of the 2 CIM into 1 DeWalt gearbox | MAteo9944 | Extra Discussion | 3 | 21-01-2007 13:00 |
| pic: Bike Cim + 56 mm gearbox | NK2007 | Extra Discussion | 7 | 15-01-2007 01:10 |
| pic: Vex 2-speed gearbox | crazykid234 | Extra Discussion | 3 | 03-01-2006 20:18 |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 07-10-2003 15:04 |
