[OCCRA]: spike relay polarity question
it seems that regarless of how the spike relay is connected, we are only able to have it switch to "red", the trigger functions does not switch to "green" when depressed. we do not have it hooked up to a motor to reverse direction, only a solenoid valve. we have tried different pwm cables, different spikes, same result.
any ideas as to why this is occurring and will it matter if only switching the solenoid? thanks bsimms |
Re: [OCCRA]: spike relay polarity question
To get it to go green ( other function) you need to push another input.
Question? Are you using the default code? If so refer to the chart that is on the IFI Website. It is a PDF File. |
| Spike relay question | Zack Briggs | Electrical | 17 | 19-02-2008 14:48 |
| Spike Relay Wire Gauge | sparrowkc | Electrical | 7 | 12-02-2008 14:26 |
| Pneumatics (Spike Relay, Solenoid etc.) Programming | oceansidehs | Programming | 8 | 10-02-2007 13:58 |
| Spike (relay) module pin out | coreyjon | Electrical | 14 | 05-04-2004 07:05 |
| Spike Relay Input | nwagers | Electrical | 3 | 16-07-2002 22:23 |
