Thread Tools |
Rating:
Display Modes |
pic: Early Christmas!
Re: pic: Early Christmas!
sorry, wrong thread.
Any comments on how the setup went?
Very cool, how do the Jags work? Must be pretty simple to set up based on how quick this is up. Do all the connectors feel nice and secure?
Also I hate to criticize, really, but how do you debug electrical problems? Seems a little messy. |
Originally Posted by Richard McClellan
According to the Getting Started guide, it is recommended to have 1/2" of empty space on the left and right side of each Jaguar speed controller. If you were to mount two Jaguars with their sides adjacent to each other, can this 1/2" space overlap, or would you need a total of 1" of space in between the two? Yes, the 1/2" space can overlap. -This is a post from another thread I thought you might want to consider this. Congrats on being ahead of the curve. Last edited by Zflash : 21-11-2008 at 09:09. Reason: spelling |
aww im so jealuoso, we havent gotten our system yet.
![]() good job goats but, clean it up. ![]() |
#7
Very quick and easy. Big thanks goes to More Robotics team 1714 for their advice on how to follow the manuals. It was a big help.
All the connectors worked fine. Wagos are easy to use. No problem about the criticism This was quick and dirty just to see how it functioned. When we decide what operations to put on the robot for testing we will do a real installation. |
#8
Please do share their advice!
#9
If they said it once they said it a thousand times....
The manuals do not flow in a linear pattern. You must be very careful how you follow them or you will be chasing your tail. Chapter one will point you to a specific section in chapter 5 and only that section. Then that section may point you somewhere else. You have to be real careful to go where you are pointed and then back. I would suggest that before you receive your control system that you download the manual and read if very carefully and familiarize yourself with it. It will make the whole process easier. |
#10
Does anyone have advice on how we should label the wires? Is there a caveat that makes it necessary to do more than, say, "SC1-P13" (sidecar 1, port 13)? I haven't investigated the Labview code yet, so I don't know what the port nomeclature looks like in the code.
#11
Personally, I would do two labels, "sc1-13" and what it corresponds to. This year our wires were labeled "pwm01" and "Left Drive" so we knew where to put it and what it was. Saved having to look it up.
#12
There are two uses of the manual, one is to get people up as quickly as possible, the other is to provide the information in a logical manner for reference. Since teams will only get up and running once, but may need to use it for reference many times, Sections 2-5 of the manual were optimized for the latter use case. Section 1 provides the pointers to the needed parts in sections 2-5, in order for everyone to get up and running.
#14
How do you get power to the router? When i looked at the istructions, it showed that it has to get connected to the power distribution board and the cRio. The only problem is that there is only one ethernet cable that came with the router and a power supply that has no use on a robot.
P.S. It would be nice for a picture of it. ![]() |
#15
Im not really liking how much space all that is taking up..
Congrats on the working robot though! |
| pic: 987's Early Christmas present 1 | KF987 | Extra Discussion | 13 | 08-01-2008 23:17 |
| pic: 987's Early Christmas present 2 | KF987 | Extra Discussion | 9 | 10-12-2007 01:36 |
| pic: Merry Christmas | AdamHeard | Chit-Chat | 6 | 18-01-2007 13:17 |
| pic: Early Drivetrain | Gabriel Mendez | Robot Showcase | 10 | 28-01-2006 00:50 |
| pic: 1559 Drivetrain--early | bradleym1559 | Robot Showcase | 2 | 07-03-2005 19:30 |
