Encoders and distance (labview)
I'm trying to program for autonomous, using the encoders. However, the formula I'm using for finding the right number of ticks for one inch and such isn't working. Does anyone have a formula, or an input value for a distance of one inch? I'm using LabVIEW. Help me please ^^
Re: Encoders and distance (labview)
If you're using the encoder VIs, then they should be doing 4x decoding. That is, they'll return 4 ticks for every cycle of the encoder. So if your encoder is 1024 pulses/cycles per revolution, the VI will actually read 4096 ticks per revolution. After that, it's just properly figuring how many inches you have per revolution.
The formula you are looking for is this
distance = (ticks) * (Gear Ratio) * (wheel diameter * pi)/(ticks per rev * scale) As I last saw them, the WPI Robotics Library encoder VI's had provisioning for real world unit distance feedback. The VI's had setters and getters for the gear ratio and distance travelled, respectively. Last edited by Tom Bottiglieri : 23-11-2008 at 12:21. |
| Labview 8.5 and encoders | MorbidAngel | NI LabVIEW | 1 | 15-11-2008 13:57 |
| Help with Angles and distance | charlie1218 | Programming | 5 | 13-12-2007 18:54 |
| How do I get distance between Camera and the target? | sjung9442 | Programming | 5 | 27-01-2006 09:44 |
| EEPROM and Encoders | Bharat Nain | Electrical | 7 | 01-12-2005 10:06 |
| Testing and Cause of Failure for Encoders and Hall Effect sensors | ChrisH | Electrical | 28 | 19-09-2005 01:07 |
