Mitsubishi Omnidirectional Rally Concept Car
Someone sent this along to me today: http://www.autobloggreen.com/photos/...-2025/1119822/
Awesome. I'm pretty sure it's not real, though. |
Re: Mitsubishi Omnidirectional Rally Concept Car
Doubt that would ever come to fruition.
Still incredibly smexy, though. |
awsome, though i dont see how it could be advantageous?(except maybe having the motors in each wheel to increase repairability)
and how could machanums work in anything other than a road |
Looks like it was designed by a stylist with a poor grasp of racing...or maybe they're envisioning some rally unlike any that I've ever seen.
Why put up with wasting 30% of your power going forwards? That's really the biggest question. What race has so many curves that straight-line acceleration is irrelevant? Also, you'd need a fancy suspension to keep the wheels on the ground. Not the transverse leaf springs described, mystery memory metal or not. Lift a wheel in a critical corner and you're in big trouble. Some of those mountain rallies have sheer drops among switchbacks...that might end badly. Imagine trying to negotiate the Dakar with wheels like that. (How are mecanum wheels on sand, anyway? My guess is awful.) And the cockpit is ridiculous. Unless this is a remote-controlled rally, it doesn't help to go sideways if you can't see out of the stupid car. As an exercise in styling, it's definitely interesting. |
It does appear to be real; it is all over the auto blogs. Still though, it will never see production.
As real as any other fantasy, I suppose
![]() Great fodder for video game designers, at the least. |
#7
The Jeep Hurricane was almost a swerve drive.
They could have made it go sideways if they had wanted... At least THEY actually built one. ![]() |
#8
I do want a car that can go sideways, just to make parallel parking easier. I don't need it to be fully holonomic: One direction at a time is fine. Mecanums are cool, but Not what I need.
That being said, I don't think that this particular car is attempting to appeal to my small wallet. |
#9
What you are describing goes for a large number of airplanes, satellites, the Segway, and a bunch of other things that would blow up and tear itself to pieces if you do it incorrectly.Last edited by Adam Y. : 25-11-2008 at 11:45. |
#10
And where do you put the electrical system to drive such a thing? Typically, electricity is used to make either heat or magnetism, which drives the memory metal device. If it's resistance-heated, you can heat it easily (and maybe even quickly), but you'll have a hard time cooling it at the same rate. If it's magnetic, the coils needed to generate the necessary field strengths will be large and heavy, and will have to be positioned in awkward places (because the effect is localized to the regions of high field strength). Hysteresis is a huge problem with this idea, in either case. This begs a question: is the controllability of the memory metal spring keeping the wheel on the ground, or is there some other active suspension component? Active suspensions currently depend on having very powerful electric or hydraulic actuators that can make quick, forceful and precise movements. So if there's some of that technology in there as well, then it would be a whole lot more practical. Like I said, I don't think it's an engineered design study. |
#11
It definitely looks more like an artistic design study
![]() But they do have 15 years to figure it out...you never know! |
#12
i looked through the rest of those pictures, they are all very impressive renders/drawings. i especially liked the car/boat/plane idea, even though it wouldn't be possible.
#13
http://www.blogcdn.com/www.autoblogg...bishi_05_l.jpg
It appears as though their wheels are oriented incorrectly as well. |
#14
....as in, you can't drive sideways?
#15
Yes that is correct you would not go sideways unless they changed the orientation of the wheels
| paper: Omnidirectional Drive Systems | Ian Mackenzie | Technical Discussion | 2 | 28-05-2006 14:22 |
| Truly omnidirectional omniwheels? | Exotria | Technical Discussion | 38 | 06-04-2006 21:52 |
| Omnidirectional Drives Aiming High | Rick TYler | Regional Competitions | 2 | 05-03-2006 11:44 |
| Omnidirectional strategeries | hixofthehood | Rules/Strategy | 27 | 11-02-2003 06:13 |
| Omnidirectional drivetrains | patrickrd | Technical Discussion | 21 | 11-10-2002 10:54 |
