Go to Post This [Coach badge] means no-touchy the controllers. Even to save them from certain doom. - Kevin Sevcik [more]
Go Back   Chief Delphi > Other > FIRST Lego League > Lego Mindstorm Discussion
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 25-11-2008, 11:29
goffchris goffchris is offline
FRC #1884
goffchris is an unknown quantity at this point
Battery monitoring in NXT
My FLL team has run into trouble because the robot behaves very differently depending on the charge of the battery. Is there a way to monitor battery voltage? How do other teams deal with this problem?
Unread 25-11-2008, 11:33
Re: Battery monitoring in NXT
I can't speak for the NXT, but teams using the RCX had this problem too. There is an easy way to deal with it--the rotation sensor. Use that instead of a timer, if you aren't already, and the only thing that'll happen is it'll take a little longer to get to the target.
I don't know how you'd monitor the voltage. There ought to be a battery indicator that'll help, but I don't kow how much or where.
Unread 25-11-2008, 12:09
Best Available Data
FRC #1778 (Chill Out!)
Back in the days of the RCX, we had a terrible time with changing voltage. Are you using AAs or that nifty rechargeable battery pack? With AA, we found that if you put a new pair in, they have an initial voltage (charge) peak, but after a full table run through or two, the voltage (essentially the charge) remains pretty stable for multiple full table run throughs. After that, the turns started changing. I'm not sure about the battery packs, but they might have a similar behavior.
As Eric said though, making your turns use rotations instead of time will help alleviate the problem, but if you've got a long program these errors in rotations will still add up (or, they did with the RCX anyways).
If these still don't help, perhaps you could follow a line to your location, or more accurately determine your location once you've arrived. If your robot bumps against two of the walls and you count how many rotations away from them you are, you can accurately determine your position, for example.
Unread 26-11-2008, 00:28
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
If using Robolab, there is a capability to read the battery voltage (on either the RCX or NXT). I don't know if the capability exists if using NXT-G.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 26-11-2008, 04:19
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
if you're using leJOS, theres also a lookup for battery voltage and you can work out a simple table of Voltage against RPM.
| jamesyong.net |
FVC2007, FTC2008
Robot Monitoring Program team540pr2007 Programming 1 10-01-2007 15:46
Remote Pulse Monitoring System kaveena Programming 1 19-07-2006 10:02
Monitoring Current During Competition Michelle Electrical 5 06-02-2006 00:15
Current Monitoring system questions PyroPhin Technical Discussion 44 17-02-2003 15:34
Current Monitoring w/ LEMs Chipawa Technical Discussion 6 12-02-2003 22:38
