[FTC]: [FTC]: Can any one explain to me just how powerful the servos are?
hi, please explain to me what is the max. the servos can hold? and will they work for telescoping ideas???
Oh, and i almost forgot, which is better/more powerful, the servos or the FTC motors?? and one last question can you use the drive motors for raising and working the arm??? Last edited by sullivan_owns : 26-11-2008 at 21:14. |
Re: [FTC]: [FTC]: Can any one explain to me just how powerful the servos are?
I dont remember the exact power that the servo can produce, but they are way weaker than the FTC motors. I would personally use motors to make an arm unless you want to gear 4 servos together.
The disadvantage however to using motors is that 1. you have to purchase another tetrix motor controller and 2. it is heavier than servos. |
o hey thx but i made i mistake to my form, i meant which is more powerful servos or NXT motors???
Greetings, and welcome to CD. You have asked a lot of questions in you post. I'll do my best to answer as many as i'm qualified to answer.
can you use the drive motors for raising and working the arm??? Yes, you can use the motors for anything you wish. My team is using the 4 large motors to run 1 wheel each. That leaves us with the servos to run an arm. I have seen several teams using two large motors to drive with (one on each side) leaving the other two "drive" motors to run anything else they wanted to put on their robot. which is better/more powerful, the servos or the FTC motors?? it depends on what you what the motors/servos to do. if you are looking for power, or if you need somthing to turn more than 180 degrees, the motors are your choice. Servos only turn ~180 degrees and are far less powerful than the drive motors. Servos do have some advantages over motors. They return their "center" when releases and they can tell where they are in relation to that center. hi, please explain to me what is the max. the servos can hold? I believe the servos are rated for 61 oz/in of torque. That means, it can turn with a weight of 61 oz on an arm 1 inch long. As your arm gets longer the weight that you can put on the end of it decreases. Feel free to ask more questions, but let me point you to the link to the FTC manual. This can answer any questions you have about, what you can or can't do with the kit in building your robot this year. Last edited by wilsonmw04 : 26-11-2008 at 21:57. |
o hey thx alot that realli helps, but i also made i mistake to my form, i meant which is more powerful; servos or NXT motors??? and what are there pros and cons
ok Servo vs NXT motors...
Power wise? the NXT motors hands down. Pros and cons: Supposedly, the NXT motors have an encoder in them that can determine 1 degree of rotation. If that's true, and you can get it to work, that could be a VERY power motor to use. The HUGE negative to the NXT motor is the shape and the difficulty of matching it with the Tetrix metal. The servos have hard stops which can make programing easy. The biggest problem with the servos are the relative lack of power and the fact they only have 180 degree rotation. |
#7
Well...not enhance the servos, just enhance the arm lifting system. . Trust me, there are ways. Yes way*s*. |
#8
Is it possible to modify the servos so that they can rotate more 180 degrees, if soo is that allowed for the FTC.
#9
According to ServoCity, here are the servo specs
hey thx guys you have been great helps, but just to make sure altering or modifying any structural parts IS alowed right???
#12
again, check the rules for the official answer, but yes. Altering structural parts, in general, is allowed.
#13
Well, not exactly. Structural parts cannot be welder, soldered, brazed, or glued.
. Yeah, read the rules. http://www.usfirst.org/uploadedFiles...he%20Robot.pdf . That link will take you to the robot section of the manual, this will tell what all you can or cannot put on ur robot and what you can do to metal and stuff. |
#14
thx and i was also wondering, for on the NXT motors can we tread the 4 orange cirles so that we can put screws in it???
#15
Lets all email the power brokers and ask for this rule to be moded? ![]() |
| [FTC] Can We Choose the Program? | CybotronX350 | Rules/Strategy | 3 | 26-11-2008 11:25 |
| [FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) | Mr. Lim | FIRST Tech Challenge | 2 | 03-03-2008 11:54 |
| [FTC]: [FTC]: Ontario Provincial FTC Start/End Times | cbhl | FIRST Tech Challenge | 8 | 16-12-2007 13:37 |
