inconsistent wireless code downloading
Has anyone else encountered the error that when you download code the code does not change. I usually have to download code 4-5 times before the code actually changes on the cRIO. Does anyone know whats up with that?
Re: inconsistent wireless code downloading
Which environment were you using, and can you describe your test so that we can try to replicate?
Greg McKaskle |
(If you are experimenting with both LabVIEW and C++ programs, you might accidentally end up with two different programs running simultaneously, with obvious confusion. Don't do that.) |
I thought you had to change the development environment using the cRIO imaging tool before loading a program from the other development environment. Wouldn't this some how prevent the above from happening? If not, shouldn't it?
The debugging differences have to do with how exceptions are caught, or something like that. I have never looked at the details. I normally run the tool. Greg McKaskle |
So I did some testing and here is what I found. I'm using windriver and C++. If I use the debug method of running code on the robot through the RAM everything works fine however if I download the code and reboot the robot the two modes (teleop and autonomous) dont change until the robot is not in their mode. I did a really simple test (switching joysticks in teleop) and found that if i reboot the robot in teleoperated mode the joysticks wern't switched but i switched to autonomous and back it worked. the same thing happened with autonomous. any ideas whats up?
#7
sry i forgot to post that i figured out what was happening. thanks though.
| Problem downloading code | Romeo1351 | FIRST Tech Challenge | 6 | 01-12-2006 06:33 |
| Downloading code to 2005 RC | Eclipse | Control System | 2 | 23-02-2006 19:58 |
| Code error on RC after downloading "bells and whistles" version of Kevins camera code | DanDon | Programming | 6 | 10-01-2006 18:07 |
| Problem downloading any Camera code | zuckie13 | Programming | 4 | 07-02-2005 20:32 |
| Downloading Code with new Editor | gburlison | Programming | 4 | 17-01-2003 01:10 |
