Go to Post Unsure if I'll get it to work, but that's no reason to not try. - DonRotolo [more]
Unread 03-12-2008, 09:13
cougarbotics cougarbotics is offline
cougarbotics is an unknown quantity at this point
Exclamation cant get NXT to connect to controller station via bluetooth
we are using the program NXT-G. we can get the NXT to connect to the controller station by USB, but we cannot get it to connect by bluetooth. we think that maybe our bluetooth adapter (the thing that looks like a jump drive) is corrupted. we have tried using different computers, but cant it to work on either. any suggestions on what to do? is it that our NXT isnt connecting? please help. our competition is only days away.
Unread 03-12-2008, 16:06
ttldomination's Avatar
Sunny
Re: cant get NXT to connect to controller station via bluetooth
If you think your adapter is corrupted, then you would have to call Pitsco and ask for a replacement immediately.
Are you using the proper firmware?
You might want to call Pitsco anyways to find out what's going on.
1648: 2013-2014
5283: 2015
Unread 03-12-2008, 16:11
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Make sure you have your blue tooth drivers installed and working.
Also do you have to pair the computer to the NXT?
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 03-12-2008, 17:53
Billfred's Avatar
Billfred Billfred is online now
Just for the record, I moved this thread into the FTC forum.
Unread 03-12-2008, 21:53
KayyPii's Avatar
KayyPii KayyPii is offline
FRC #1404 (SHOCKs)
KayyPii will become famous soon enough
Have you added the NXT brick to your computer as a bluetooth device?
=>"That hole you drilled is a little off."
=>"Don't panic, just make it bigger and put a washer on it!"
=>Eye ball once, and cut as many times as it takes
Unread 04-12-2008, 00:19
Michael Coleman's Avatar
Michael Coleman Michael Coleman is offline
Michael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of light
- Verify that the Bluetooth Dongle is using the Generic Windows Driver.
- Is the NXT battery fully charged?
- Is the NXT Bluetooth turned on and not set to invisible?
- Is the NXT buried behind too much metal, preventing the signal from reaching the controller?
- Is the NXT too close to an active 802.11 a,b,g or N WiFi system? Turn off the WiFi source or move further away.
- Is the correct NXT name entered into the Robot Control Station?
- Are you able make a Bluetooth connection to the NXT using NXT-G? If yes, close the NXT-G program before starting the Robot Control Station.
- Remove the NXT battery for 15 seconds and try to make a Bluetooth connection.
- Run the Windows Bluetooth Device Manager. Does the NXT appear in the list of devices? Delete the NXT and re-establish a Bluetooth connection using the Bluetooth Device Manager. Next, try to connect to the NXT using the Robot Controller Station.
----Select the NXT from the device list
----Select the Properties Button
----Select the Services tab at the top of the Properties window
----The Properties Window will switch to an empty Services window with an animated flashlight to depict searching for available services for the device chosen
----When the animated flashlight finishes searching, a service (Serial port (SPP) 'Dev B') should be listed. Verify that the check box to the left of the service is checked.
----Select OK at the bottom of the Services Window
----Using the Robot Controller Station, try to establish a Bluetooth connection (up to 4 tries)
- Is the latest FTC NXT-G firmware installed on the NXT?
- Have you tried a different computer? Some brands of notebooks can insist on using a manufacturer's driver instead of the Generic Windows Driver. The Generic Windows Driver should be used.
- Did the Passkey screen appear on the NXT display? If yes, did you press the Orange button on the NXT to approve the Passkey?
- Is the NXT using the default Bluetooth Passkey (1234)?
Michael
Help! Can't send files to NXT Brick via bluetooth Raptorace22 National Instruments LabVIEW and Data Acquisition 0 24-11-2008 16:39
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
[FTC]: Bluetooth/NXT issues jbbjjbt FIRST Tech Challenge 5 23-10-2008 16:56
Cant get RC to work comphappy Control System 13 06-01-2008 18:40
Connect Playstation Controller to PC USB. kirov Control System 1 28-02-2005 08:24
