5 Amp Fuses for Analog Breakout & Solenoid Breakout
i am primarily a programmer, but this year i have also been working on electrical. we have almost finished the bench test for the new control system, but have been unable to find the 5 amp fuses for the analog and solenoid breakouts as called for in the documentation. anybody know where to find them or another alternative?
Re: 5 Amp Fuses for Analog Breakout & Solenoid Breakout
20A breakers are fine but unnecessarily large. The Digital Sidecar and Analog Breakout cannot supply more than a few amperes hence the typical breaker size of 5A shown in the datasheet. If you fully utilize the Solenoid Breakout, you'll want to consider using a 10A breaker to power that module (8 channels at 0.75A each).
Please heed the disclaimer in the datasheets regarding FIRST rules taking precedence. Some of the details shown may conflict with the official rules. When wiring, you always need to match the wire size to the breaker size (and preferably to match the load as well). If you can find and use a 5A breaker, you'll be able to use a smaller diameter wire per the datasheet. With a 20A breaker (the smallest provided in past kits), you need to use 18AWG or larger diameter wire. Go ahead and use a 20A breaker for now. Depending on the 2009 robot rules, you may be forced to use a specific breaker. Or you may be allowed to pick and choose to suit your needs. We'll see soon... Russ |
Chris I think I broke the robot.
Don't tell Mr. Sheridan ![]() |
thanks!
| Pneumatic breakout question. | IndySam | FRC Control System | 5 | 23-12-2008 17:10 |
| 20 amp fuses for Spikes | Andrew Schuetze | Electrical | 8 | 01-04-2003 22:18 |
| Where can I get 60 Amp Fuses -- that look like 30 Amp Fuses? | Anton Abaya | Chit-Chat | 4 | 12-01-2002 14:09 |
