UI Board Object Specs
I'm trying to lay out a general UI board for the new season, but I can't find any specs for anything dimension wise on any of the spec sheets.
Could anyone be so kind to provide dimensions for
Please and thanks! |
Re: UI Board Object Specs
Driver Station: 6 1/8" x 4 5/8" x 1 3/16"
For off the field use you need an extra 2 1/8" on the left for the disable dongle, and you need clearance on the right for the USB ports and the breakout pins if you use them. Logitech Attack 3 Joystick: 6.5" x 6.5" and 8.5" tall Router: 9" wide x 7" tall x 1.5" high Make the router come off for competition though. |
No need to make the router come off for competitions. Just make it easy to unplug the cable.
We've had all our boards in the past with the radio mounted on it - we just removed the serial cable when we got to the competitions. |
| rangefinding/object detection | sciguy125 | Electrical | 14 | 13-01-2008 20:36 |
| pic: Wierd Moon Object | Qbranch | Extra Discussion | 24 | 23-05-2007 16:28 |
| Object Enablers | SherryG | Inventor | 1 | 07-04-2006 10:01 |
| Changing the visibility of an object | 65_Xero_Huskie | 3D Animation and Competition | 9 | 28-01-2006 17:12 |
| The object of Zone Zeal???? | Jay5780 | General Forum | 15 | 09-04-2002 19:54 |
