Go to Post I normally prefer my speed controllers to brake, rather then break. - Joe Ross [more]
Unread 10-12-2008, 18:00
NetSkay NetSkay is offline
FRC #1793
NetSkay is an unknown quantity at this point
cRIO test drive *OFB* problem....
we got the control stuff couple of weeks ago, and today i got around setting it all up, i followed the diagrams and manuals (which i would like to note are incompatible with what came and i also expected a bit more stuff to come in, like more cabling, proper PWM IO cables and etc.)...
when we turned the driver station, everything was tip top, it booted, then i followed the manual and put it in disabled and teleop and shut it off... then we started the cRIO and all components connected to the power board, and everything blinks and works as it should, just like the manual said...
then came the operational test... we started the driver station, then we connected the ethernet cable from the driver station to cRIO ethernet port #1, and started the cRIO and all components, joysticks were connected to driver station USB 1 and 2 also... when the cRIO started the ethernet LEDs started blinking, im guessing DHCP address allocation of some sort, we tried to move the joystick, but the jaguar PWMs just kept bilnking... the ethernet LEDs never idled, always blinked... and at the end no motor movement...
any ideas?!
also whats the deal with the split PWM cables for the jaguars? and no cable for the victor... *sign*
Unread 10-12-2008, 18:11
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: cRIO test drive *OFB* problem....
Did you enable your robot? Did you wait 30 seconds to a minute for it to resume functions?
- Arizona North
Unread 10-12-2008, 18:15
FRC #1793
u mean after everything is powered on and connected, ill have to wait 30 more seconds after i switch the toggle to enabled?!
im just trying to perform the benchtop tests, and this is the very first one after each of the components have been tested individually... the driver station is directly connected to cRIO on ethernet port #1
Unread 10-12-2008, 18:21
FRC #1793
the screen said the normal stuff
TEAM: 0000000...
MODE: Teleoperational
System Disabled
Battery N/A
*OTB*
then i flick the toggle and system switches to Enabled, but nothing happens, the jaguars still blink, so do i have to wait for like a minute or something before i can try the OTB joystick test or....
Unread 10-12-2008, 18:32
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
It takes a while for the DS and cRIO to fully start up and sync after powering up, but if you're tethered it shouldn't take more than a minute.
After that, when you enable the robot, the system should respond almost immediately (+- a few secs).
If you're not getting a response from jags, try using servos in their place (don't forget the jumper!).
Unread 10-12-2008, 18:13
"split PWM cables for the jaguars" - hmm? You should be using regular pwm cables. A bunch came with the control system, but you'll have to take off the cover on the female side and trim the tab on the male side.
You can also test if you're getting an output by connecting a servo to pwm 1 or 2, and adding a jumper next to the connector on the sidecar (for servo power).
Also, to go through the obvious things:
did you enable the robot with the switch?
what does the DS screen say?
cRIO plugin problem gabrielse National Instruments LabVIEW and Data Acquisition 3 18-12-2008 11:30
[FTC]: 35's Drive problem wilsonmw04 FIRST Tech Challenge 30 15-12-2008 07:28
Mystery problem: exponential drive ida_noeman Programming 9 21-01-2007 12:39
TechnoKats Automated Test Drive Code Greg McCoy Programming 1 16-01-2003 17:45
