Go to Post There's more than one way to skin a cat. - Al Skierkiewicz [more]
Unread 10-12-2008, 20:33
naruto137 naruto137 is offline
FRC #1656
naruto137 is infamous around these partsnaruto137 is infamous around these parts
Drive Train Components: the inner working parts of a drive train
So call me a noob but I am just wondering, what are the ways in which you can use components to drive your robot besides just using direct motor to wheel drive and what and why are the advantageous? (ie chains, gearboxes, etc)
I am mainly wondering about not the various drive trains, but the different components that can be used in the drive train, like how exactly gearboxes can be used, the types and such and how they would be advantageous, or how gears can be configured in a certain way and how that would help, or anything else like that.
Thanks!
Unread 10-12-2008, 20:38
Re: Drive Train Components: the inner working parts of a drive train
Other than direct drive? Well, I can only think of three or four.
Chain drive: run a chain to a sprocket that is attached to the wheel(s) you want to drive. It's a reliable connection if done right, and there's some "give" in the system.
Belt drive: See chain drive, but watch out for slipping. It's a little lighter.
Tank treads: Can put the tread through the gearbox if you want.
Gear drive: use gears instead of chains to link the wheels. Team 25 is one of the "expert" teams on doing this, IIRC.
As for the components and their uses, use your imagination.
Also, you might try searching for drivetrains, gearboxes, transmissions, and similar things both in the forums and in CD-Media.
Unread 10-12-2008, 20:56
logicalyrandom logicalyrandom is offline
FRC #1787 (Flying Circuits)
Team Role: Electrical
logicalyrandom will become famous soon enough
Not FIRST specific, but this site is a great resource for drive train info. Should give you the info you want.
If there is no possibility of shrapnel, you did it wrong.
Unread 10-12-2008, 21:14
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Here a two of the main places teams get pre-made gearboxes:
http://banebots.com/c/GEARBOX-PLAN
http://andymark.biz/amshifters.html
both of these sites provide gearboxes that are compatible with the CIM motors.
Mens et Manus
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: team696 teaser of the Drive Train. xKLzKobE08x Extra Discussion 16 30-01-2005 22:59
Choosing an Encoder for the Drive-train MikeDubreuil Electrical 11 21-10-2004 00:50
pic: Team 60 Drive Train Parts CD47-Bot Robot Showcase 17 07-02-2004 01:58
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
