Go to Post FIRST is all about working with others. - briholton [more]
Unread 18-12-2008, 15:37
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
80/20 chassis
My team was looking into using 80/20 for our chassis this year, and we couldn't decide what sizes to order. Does anyone have suggestions for what size of 80/20 to use for the chassis and/or extremities?
If you worked with 80/20 last year and could summarize the purchases that you made into a basic "parts list" for getting started, this would be great.
We began looking into 80/20 earlier this season and have heard that about 1000 linear inches should be sufficient for a basic chassis. Can anyone confirm? What should we add? Which connectors/fasteners have been successful?
Thank you.
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 18-12-2008, 15:41
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: 80/20 chassis
Thank you.
1000in is more than 83'. That's a lot of 80/20. 100in is more reasonable, but may not be enough on its own to building a complete frame.
--Madison--
...down at the Ozdust!
Unread 18-12-2008, 16:31
alphageek365's Avatar
alphageek365 alphageek365 is offline
AKA: Kirstin
FRC #0365 (MOE)
alphageek365 is on a distinguished road
Re: 80/20 chassis
Moe has used 10 series and 45 series 80/20 and Bosch extruded aluminum for the past few years. We found it worked well especially for assembling and testing functions, arms, lift systems, etc. But during competition you'll find the joints come loose. Just make sure your team tightens the bolts every time your bot comes back from the field.
For our major functions we weld Aluminum angle and tube. After this year we decided to weld the entire frame including the chassis to improve the rigidity of our bot.
You'll need about 300 to 350 inches in length for a basic box bot and some functions.
Good luck!
Unread 18-12-2008, 16:59
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Re: 80/20 chassis
1712 has used 80/20 extrusion systems for 3 years. Search cd media for 1712 and you'll find some chassis pictures. The amount you need varies based on manipulators, etc but I'd be glad to elaborate more if you'd like. For connectors we use the smaller drop in t-nuts and hidden corner connectors. We used to use the plates, etc...less expensive but more weight/space. We purchase all of it from Mcmaster-Carr. Let me know if you want part numbers, etc and I'll get you some info.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 18-12-2008, 17:32
run the trap!!!
Team Role: Human Player
Re: 80/20 chassis
Last year we used two 38" long 1020 (1"x2") in our drive.
In 2007 we used four bars of 1010 in our drive.
80/20 is best used sparingly, we don't use much of it outside the drive train. We don't bother with the fasteners. We just tap the ends (1/4-20) and weld it together. Its much cheaper, lighter, and stronger that way.
There is an ebay store that sells the stuff at good discounts. Although we have a supplier here in the Bay Area that gives FIRST teams a discount. Careful who you order from. The so called "80/20 suppliers" don't always keep 80/20 in stock as I have found out the hard way...
-Philip J. Fry
Unread 18-12-2008, 17:38
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: 80/20 chassis
16 has used 80/20 for the past two years with pretty good success. See what they're up to.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 18-12-2008, 18:36
BlackBird11891's Avatar
BlackBird11891 BlackBird11891 is offline
We Rise Above Our Challenges
AKA: Chad Krivanec
FRC #1927 (Team Tempest)
BlackBird11891 is on a distinguished road
Re: 80/20 chassis
our fork lift assemblie used 80-20 last year and for the strength that u get for it its way over weight... the kitbot s alot better... the 80-20 worked well for everything else go and is great for manipulator, lifts etc. we used 1" 80-20
Unread 18-12-2008, 19:45
Woodie Flowers Award
JDNovak JDNovak is offline
AKA: John Novak
FRC #0016 (Bomb Squad)
JDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond reputeJDNovak has a reputation beyond repute
Re: 80/20 chassis
We (The Bomb Squad) have used extruded aluminum for all our frames since 2003. We have always used 20mm x 20mm ITEM brand material purchased from the US distributor in Ohio. They offer a discount to FIRST teams.
The material is amazingly strong for its size and weight. As someone already stated, joints tend to loosen from impact but a good design can minimize that. I believe a bare frame can be made as light as any other construction with some practice. ITEM also has a lot of neat fasteners like slides and rollers that make arms and elevators easy to design.
The major issue of this construction is fasteners. To take advantage of the material we use "T" nuts with M5 screws to fasten everything to the frame from gussets to gearboxes. The advantages are no reduction in strength and the ability to slide structures for alignment and chain tensioning etc. The disadvantages are weight and cost. The ITEM "T" nuts cost a dollar each before discount and the 80/20 distributor I checked recently charges $1.25. We usually use two hundred or more a year initially and probably twenty-five more fall out during competition.
I really can't guess how much material you need without knowing a lot more details. We usually use four rails extending from front to back internal of the wheels to support the upper manipulator/drives etc. and then build a frame that tapers at the back to take advantage of our three wheel drive system. U shaped frames for ball pickup are more difficult to strengthen but we have done it.
I would get some material and build a box first and get a feel for the weight and strength and then go from there. You can always use the box for storage if it doesn't suite your needs.
Oh, I think ITEM and 80/20 as well as some other brands I have seen are equivelant but not always compatible between them.
Unread 18-12-2008, 21:42
DonRotolo's Avatar
Back to humble
FRC #0832
Re: 80/20 chassis
We used Item material also 2 years ago, for the frame and ball shooter. It is great to work with, I recommend it, but note that we went back to the kitbot last year...
Don
Unread 18-12-2008, 22:56
Gdeaver Gdeaver is online now
FRC #1640
Re: 80/20 chassis
Team 104 made our frame from the 8020 quick frame material and connectors. We literaly hacked and wacked our frame together. Held up well in the comp and was lighter than our past kit bot frames.
Unread 18-12-2008, 23:21
AKA: Chad Krivanec
Re: 80/20 chassis
As previously mentioned 80-20 does have many different fasteners that do come in handy such as
which was used to attach a solenoid to it &
which we used to connect two pieces at 90 degrees
this is our 80-20 that we used
Unread 19-12-2008, 02:16
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: 80/20 chassis
When I was on 100 we used 1010 80/20 in 2003 and 2004. Didn't have any strength problems.
2001-2004: Team 100
2006-Present: Team 254
Unread 19-12-2008, 07:52
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: 80/20 chassis
Foot for foot, 80/20 aluminum isn't that much heavier than 1x1x0.0625-wall extrusion. The biggest weight difference is in the fasteners -- to stiffen the 80/20 frame, make sure you allocate enough of your weight budget for plenty of bolts. This year our lift overran it's original weight calculation by ~15% due to extra nuts/bolts that were added at the base.
We used 80/20 for our lift in 2008 and noticed severe torsional forces when the lift was high and everything was under stress. That said, I'll echo MOE's comments that the frame needs to be stiffened at the end of every match. Another option is to sandblast/clean off the outer coating, and weld it. Usually a local machine shop is willing to donate an hour for this if you time it correctly and plan in advance. Welding would significantly improve the stiffness of the frame. Even better, you could take a 80/20 'jig' in, bolt the frame to the jig, then the welders would have plenty of room to weld the frame joints together without worrying about having to lay out your frame, or warping as the frame cools.
GitHub
Unread 19-12-2008, 08:54
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
Re: 80/20 chassis
Quick note on 80/20,
DON'T DROP YOUR NUTS!
80/20 is great but can suck at times....
"Measure once, cut twice... wait... what?"
"Two things needed to build a robot.. WD40 for the things that don't move but should, and Duct tape for the things that move but shouldn't"
Unread 19-12-2008, 09:25
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: 80/20 chassis
I've been lobbying for my team to use 80/20 or other extrusion for a few years. We might use it this year, since (a) my employer uses a lot of it (we've literally built buildings and cleanroom support structures out of it), so we get a lot of leftover material, and (b) we're such a good customer that occasionally the supplier lets some stuff "fall off the truck". I think I've got enough basic stock so that we can at least prototype a frame with it this year.
Chassis Torboticsmember General Forum 2 30-01-2008 16:30
autocad chassis kDude CAD 7 16-01-2008 10:07
Chassis Materials neoshaakti Technical Discussion 30 12-11-2007 21:08
Chassis? jakey Kit & Additional Hardware 1 09-01-2006 15:10
Chassis ark_1230 Technical Discussion 2 04-09-2002 22:51
