Go to Post When you do something great, it just feels good. - tiffany34990 [more]
Unread 22-12-2008, 21:14
Straberrie's Avatar
Straberrie Straberrie is offline
The Plague
AKA: Rebecca
FRC #0375 (Robotic Plague)
Straberrie will become famous soon enough
Axis Camera in C++; code error??
Hi! Currently, I am trying to program the camera and the bot so that when it detects green, it aligns itself with the traget, but since i epicly phailed at that, I decided to do something simpler and just make the bot go forward when it detects green! I made this code *well, technically I used the guide and didnt really MAKE it* and i am getting 2 errors.... And i cant figure out whats wrong! help would be appreciated! THANKS!
So here are the headers I used:
#include "WPILib.h"
#include "AxisCamera.h"
#include "Servo.h"
#include "SimpleRobot.h"
#include "SensorBase.h"
#include "Error.h"
#include "ErrorBase.h"
#include "FrcError.h"
This is the rest of the defining and stuff!
class RobotDemo : public SimpleRobot
RobotDrive *Bot; // robot drive system
Joystick *stickRight;
Joystick *stickLeft;
DriverStation *ds; // driver station
public:
RobotDemo(void)
if (StartCameraTask ()== -1) {
printf( "Failed to spawn camera task; Error code %s",
GetErrorText (GetLastError()) };
ds = DriverStation::GetInstance();
Bot = new RobotDrive(1, 2); // create robot drive base
stickRight = new Joystick(1);
stickLeft = new Joystick(2);
Range greenHue, greenSat, greenLum;
greenHue.minValue = 65; greenHue.maxValue = 80;
greenSat.minValue =100; greenSat.maxValue = 255;
greenLum.minValue = 100; greenLum.maxValue = 255;
GetWatchdog().SetExpiration(100);
and here is the autonomous:
void Autonomous(void)
GetWatchdog().SetEnabled(false);
while(IsAutonomous())
if( FindColor(IMAQ_HSL, &greenHue, &greenSat, &greenLum, &par)
&& par.particleToImagePercent < MAX_PARTICLE_TO_IMAGE_PERCENT
&& par.particleToImagePercent > MIN_PARTICLE_TO_IMAGE_PERCENT )
{Bot->Drive(1.0, (float)par.center_mass_x_normalized);}
else
Bot->Drive(0.0, 0.0);
Wait(50);
Bot->Drive(0.0, 0.0); // stop robot
and the very end line of the code:
START_ROBOT_CLASS(RobotDemo);
I highlighted the lines where i get an error; basically on the get error one, they say the function was not defined.... and it also highlights the Start Robot Class thing as wrong. And is camera initiated/used right? Because in the guide, there are different things on different pages and I did not know what to use... Sorry for the lengthy question.
Team 375: The Robotic Plague
Current Robot: I-Chihuahua
Last Event: Big Apple Breakaway
Unread 22-12-2008, 21:38
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Axis Camera in C++; code error??
You're missing a closing round-bracket on the 1st line. You have a ')' for GetLastError, then a ')' for GetErrorText, but you're missing a ')' for printf. It should be
GetErrorText (GetLastError())) };
Unread 22-12-2008, 21:43
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Change the lines
to
if (StartCameraTask() == -1)
	printf("Failed to spawn camera task; Error code %s", GetVisionErrorText(GetLastVisionError()));
It should compile now (See FrcError.h for these declarations - the headers were probably changed after the documentation was written).
(P.S. Your #includes for servo.h, simplerobot.h, sensorbase.h, error.h and errorbase.h are extraneous, since they are included by wpilib.h)
Unread 22-12-2008, 21:52
Straberrie's Avatar
The Plague
AKA: Rebecca
THANK U!!!!!!!!!!
and really?? I thought maybe the get error thing would be in one of them, but YAY! ty!!!
Program Axis Camera in c++ excel2474 Programming 5 22-12-2008 17:14
Axis Camera Testing help koo_04 Programming 7 20-12-2008 13:55
axis camera - problem s0crates FRC Control System 11 16-12-2008 09:34
Error in Compiling the Camera Code (B&W Version) VetteSlick Programming 7 20-01-2006 20:50
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
