Go to Post If you're in Israel, it might be a long flight to the nearest Walmart - MrForbes [more]
Unread 29-12-2008, 00:25
16MentalTempest's Avatar
16MentalTempest 16MentalTempest is offline
Amateur Animator
FRC #2046 (Bear Metal)
Team Role: Animator
16MentalTempest will become famous soon enough16MentalTempest will become famous soon enough
Rendering Problem
I've had problems with rendering. As the attached picture shows, the carpet gets cut off a certain distance away from the camera, no matter how large the plane is. Is there a way to solve this?
Regional Competition To-Do List:
1) Have fun
2) Be safe
3) Meet new people
4) Help other teams
5) Try to win
Unread 29-12-2008, 08:57
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
Re: Rendering Problem
It looks like what's going on is that you do not have enough light in the scene. Try adding omni lights above the table and see what that does to the render.
Unread 29-12-2008, 21:30
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
I'm guessing your models are WAY to big. I wont tell you until I see a screen shot of max with your models in it. Make sure to show me the 4 view ports with the grids turned on.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 29-12-2008, 22:31
Amateur Animator
Team Role: Animator
Unfortunately, the file with this scene was corrupted a week ago, so I can't open it. The table was only a few feet in all directions. If I remember right, the ball was only a few inches in diameter. How would have too big of models cause this?
1) Have fun
2) Be safe
3) Meet new people
4) Help other teams
5) Try to win
Unread 29-12-2008, 23:02
FRC Key Volunteer Trainer
AKA: CrazyNate
Its been a while since I've worked with Max, but here's my short version of the answer you're looking for...essentially, when you do a zoom extents on your perspective window(or the equivalent for a camera), it makes sure you can see EVERYTHING - including all the edges of your "table". Essentially, what you need to do is to manually zoom into the image until you can't see the edges any more, and then render from that view. For setting up my camera shots when I worked more with Max, I would normally change that viewport to a shaded view, rather than wireframe. I found it much easier that way to get the proper perspective of things...
Nate Smith
nsmith@smythsoft.com
Unread 30-12-2008, 14:30
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
always Always save your file and then choose "Save Copy as" you will never run into a problem like that again.
As far as how big a model should be. I normally keep it within the defalt grid in the perspective screen. Then when I need to combine models I will rescale it then always reset the xform so I don't run into hiarchy problems. This really only works for stationary objects like scenery.
Rigged or Skinned objects (normally characters) are different. I'm my preference you will run into a mess of problems if you don't pay attention to the size when you rig them. Make sure they are the final size when you skin your characters. So you better have very good communication when you are having multiple characters.
A.K.A Llama
Rendering Problem in IE Zholl Website Design/Showcase 12 19-12-2008 16:49
Rendering help marlon_jbt Website Design/Showcase 10 15-10-2003 21:07
Rendering Power riley_ag 3D Animation and Competition 23 04-03-2003 12:17
Net Rendering Tyler Olds 3D Animation and Competition 14 15-03-2002 15:55
Problems rendering Tyler Olds 3D Animation and Competition 8 24-01-2002 22:34
