Labview NXT Servos
I try to shift from a value of 0 to 180 yet I only get a 45 degree move.
How do I take advantage and achieve the full 180 degrees of movement possible with a servo? Any help would be appreciated. I can get to one extreme but not the other extreme on the other side. I have values between 0 and 254. It won't let me put in negative values which I tried to do. Also can someone explain the Scale Servo VI to me please? I have a feeling I should be using it but am unsure what it does or how to use it to effect the servo performance. Thanks for your help. Last edited by quizbiz : 29-12-2008 at 13:20. Reason: learned more about my problem |
Re: Labview NXT Servos
Do you mean using LabVIEW with the FTC (NXT) Servo controller? FTC Servos go from 1 to 255 (not 0 to 255). 1 and 255 are the extremes. Sending a position of "0" just goes to the last commanded position. (handy for keeping the servo in position whitout knowing were it was last sent ![]() |
| LabVIEW with NXT sensors | gabrielse | National Instruments LabVIEW and Data Acquisition | 13 | 05-01-2009 02:02 |
| Battery monitoring in NXT | goffchris | Lego Mindstorm Discussion | 4 | 26-11-2008 04:19 |
| Frozen NXT Brick. | devinejohnny | General Forum | 2 | 05-11-2008 21:34 |
| Learning Labview Tookit on the NXT | lynca | NI LabVIEW | 2 | 04-05-2008 16:01 |
| Lego MindStorm NXT | Gamer930 | Lego Mindstorm Discussion | 1 | 10-07-2006 09:21 |
