Omni Casters!?!?
Should non-driven omni wheels be allowed as casters?
Re: Omni Casters!?!?
I don't think so because they provide some (though very little) traction and all traction to the robot is supplied by the rover wheels only
I don't think they will be allowed. However I have to tell you that any caster or wheel that isn't powered will reduce your effective pushing power.
Edit: They say the only things allowed to provide traction are rover wheels, but they say nothing about normal force. It does raise one issue: there must be no friction between the omni wheels and the ground, something impossible to do in reality. Last edited by usbcd36 : 04-01-2009 at 13:12. |
It says specifically that you can only use the Rover wheels.
NO more no less... That was my understanding |
#7
any wheel provides rooling friction which may be considered traction. q&a will be the final answer
#8
Traction is, by definition, the force of an object on another object and, in FIRST, that object's force of grip on the ground, meaning the only thing that you can use as "traction devices" (as in something touching the ground) are the "rover" KOP wheels.
| Casters | merybar | Technical Discussion | 9 | 22-01-2008 22:15 |
| Effectiveness of Casters | ND4SPDLSC | Technical Discussion | 35 | 26-01-2004 23:08 |
| Casters | CHSRobotics03 | OCCRA | 3 | 21-10-2002 20:27 |
| casters | archiver | 2000 | 2 | 24-06-2002 00:11 |
| Modifying Casters | Jim Meyer | OCCRA | 1 | 05-10-2001 21:15 |
