Go to Post Kids should already be motivated to build the best robot they can, and learn as much as they can. They shouldn't need extra incentives. - Matt382 [more]
Unread 05-01-2009, 21:16
Torbots 1197 Torbots 1197 is offline
Chief Tormentor
FRC #1197 (TorBots)
Team Role: Communications
Torbots 1197 is an unknown quantity at this point
cRIO configuration issue- serial connection to laptop
We're trying to set up the serial connection for the cRIO. We can get a terminal window open inside wind river and it tells us that it's connected, but when we turn on/ reset the cRIO, it doesn't give us the little message indicating a successful boot that 5.4.1.3 says we should get. We've set up the terminal window exactly as described in section 5.4.1 of the control system manual. We've got the console-out dipswitch in the on position. We've also made sure the null modem cable we're using is good. Does anyone know what's wrong?
Unread 05-01-2009, 21:36
legend legend is offline
The Finisher
legend is an unknown quantity at this point
Re: cRIO configuration issue- serial connection to laptop
Are you using a regular serial connection or a USB to serial converter? I have seen a similar problem in PCs that do not have the serial connection.
Unread 06-01-2009, 13:06
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
If I recall correctly, you must use a null modem cable between your computer and the cRIO instead of a standard serial cable. It's just like making a serial connection between two normal computers.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 07-01-2009, 21:28
Chief Tormentor
FRC #1197 (TorBots)
Yeah, we got a null modem cable. That's why we're so surprised it's not working. We've also checked all the settings many times to make sure the connection's set up right: 9600,8,1,none,none, and the right com port. Any other common errors?
Unread 08-01-2009, 11:15
Can you confirm that the serial port on the computer is not broken?
Try to connect to the cRIO with a different computer with hyperterminal
Unread 28-01-2009, 22:28
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
We plugged in our null modem to the cRIO, ran Hyperterm on the PC with COM1: 9600,8,n,n as you suggest with the console dipswitch set to ON and it worked first time. Ensure your serial port is enabled in the BIOS, enabled in Device Manager and no one has tinkered with the IRQ's etc.
I would also recommend testing with another PC.
Tony,
1711 Raptors
cRIO/Driver Station output to laptop smcmahon FRC Control System 3 14-12-2008 13:51
Tricks getting the CRIO to talk to laptop mac7attack FRC Control System 10 08-12-2008 09:20
The poor serial port less laptop owners with a ExpressCard Slot Kingofl337 Programming 8 11-03-2008 22:25
Dell laptop serial port notquitehere188 Programming 18 26-10-2006 22:32
Code Download via Serial Issue phrontist Programming 9 08-02-2005 17:32
