Go to Post Part of Gracious Professionalism is the Professional bit. Doesn't matter if you're a volunteer or a staff member, a failure of this level in the real world would result in getting fired. - [more]
Unread 06-01-2009, 00:19
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Weight of Trailers
So, what is the exact weight of the trailers? I've heard that they're 20-25 pounds or so but an exact answer would be appreciated. I realize that plywood does vary in density a little but withing half a pound overall would be an awesome estimate.
thank you, Vivek
"we don't build robots, we build people"
Unread 06-01-2009, 00:22
Danny McC's Avatar
Danny McC Danny McC is offline
Taking one home in '09.
AKA: Danny McCanney
FRC #0816 (The WesTech Anomaly)
Danny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant futureDanny McC has a brilliant future
Send a message via AIM to Danny McC Send a message via MSN to Danny McC
Re: Weight of Trailers
I dont know. My one advisor said they only weigh about 15 lbs. But I have been hearing different things everywhere.
Unread 06-01-2009, 06:56
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
We would like to know that too.
Doug Leppard
Unread 06-01-2009, 07:39
vivek16's Avatar
AKA: vivek
No promises but I'll try and calculate it using inventor by setting mass properties for the model that I obtained for the trailer. I suspect an actual weigh in would be more accurate.
thanks, Vivek
Unread 06-01-2009, 07:41
GaryVoshol's Avatar
Cogito ergo arbitro
How about the tongue weight?
(since 2004)
Unread 06-01-2009, 23:12
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
I've built parts for six trailers for the Peachtree Regional Kick-off and Scrimmage and have assembled two of them completely. I used the actual plans that FIRST uses to make the official trailers. I built ours exactly to spec except that I used Sono tube for the target rather than the HDPE. In spite of this, I have the HDPE and have weighed the trailer and appropriate amount of HDPE in place of the Sono tube.
Using bathroom scales, I find that the trailer is 35-36 pounds.
I haven't checked the tongue weight yet, but it is slightly tongue heavy. The CG is pretty high on these so a slight change in height of the tongue will change the tongue weight significantly. That shouldn't be a problem since the tongue should always be the same height above the floor.
I'll try to check the tongue weight in a day or so when I assemble another one.
I've been reading posts and notice that not enough attention has been paid to the problems that the trailer will cause. With robot, bumpers, battery and a 35 pound trailer, plus some moon rocks you are up around 180-190 pounds!
Retired Starman
Team 1648
Atlanta, GA
Unread 07-01-2009, 18:12
gregscott gregscott is offline
gregscott is an unknown quantity at this point
Just making sure...and I really appreciate the information, I do understand how much the trailer will effect vehicle dynamics...you used alumalite and coroplast for these trailers and not plywood? They are both very lightweight materials.
Thanks again,
Greg
Unread 07-01-2009, 18:15
DM7000 DM7000 is offline
AKA: Dan Marino
FRC #2574 (Robohuskie)
DM7000 is an unknown quantity at this point
Send a message via AIM to DM7000
I think the trailers are around 40 pounds or so plus the weight of the balls.
Unread 07-01-2009, 18:28
vivek16's Avatar
AKA: vivek
Retired Starman (or anyone else who had built their trailers exactly to FIRST's specs),
Can you please measure the weight of the trailer without and with balls loaded on scales accurate to the .1 lbs?
The mass of the trailer is REALLY going to make a difference in driving this year.
Unread 07-01-2009, 19:40
BetsySpike BetsySpike is offline
FRC #0291 (CIA Team 291)
BetsySpike is an unknown quantity at this point
Send a message via AIM to BetsySpike
We should be done with our trailer tonight or tomorrow according to all the FIRST specs. I will post the weight as soon as possible.
Unread 08-01-2009, 20:44
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
35 balls weighs 17.5 lbs.
Unread 17-01-2009, 17:02
Ozeaden Ozeaden is offline
FRC #1388 (Eagle Robotics)
Ozeaden is an unknown quantity at this point
mostly in the end if you add your robot, your bumpers, and the trailer, its about 180 lbs so its about 40 ish.
http://www.eaglerobotics.com/
Unread 09-01-2009, 21:31
Retired Starman
Team 1648
Atlanta, GA
Do you find out the tongue weight?
Doug Leppard
Unread 09-01-2009, 22:22
no.1manenti's Avatar
no.1manenti no.1manenti is offline
Brandon
FRC #2832 (Warriors)
no.1manenti is an unknown quantity at this point
wow 35 pounds is a lot of weight on the back of the robot. How much would you figure the trailer weight is when its full with balls? they dont seem that heavy but I know that the weight adds up quick.
Unread 09-01-2009, 22:46
FRC #3573 (Ohms)
I'll have a tongue weight sometime this Saturday after I finish another trailer. I don't have access to a scale accurate to 0.1 lb that I can put one of these things on. I may be able to get that for you next week. These things are pretty big and unless you have a large platform scale, it is very difficult to weigh them. Thirty-five pounds is the design weight and that is very close to what I got on my bathroom scales. That's built with Alumilite and the Coraplast or whatever that corrugated plastic is called, just like the plans called for. I can't tell you what the weight is full of balls because I don't know how many balls you can get in there. I've heard of one team that loaded over 80 of them in one trailer, but I haven't confirmed that. Let's face it, if someone has scored 80 balls in your trailer, you aren't going to win that match anyway!
Retired Starman
Team 1648
Removing game pieces from Trailers PhilBot Rules/Strategy 51 06-01-2009 17:19
Is pinning opposing robots trailers allowed? spiffyspleen Rules/Strategy 22 05-01-2009 16:47
Weight? Estmate weight? Arkorobotics General Forum 21 29-01-2007 17:34
Wait...weight...weight!!!! Greg Perkins General Forum 3 22-02-2006 07:42
Weight??? candy12 Technical Discussion 1 16-02-2003 17:48
