Go to Post FIRST continues their full-frontal assault on mentor's vacation days. - Lil' Lavery [more]
Unread 06-01-2009, 15:28
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Question CRIO Error 60
ok... heres the deal, we got the CRIO to finally connect to the PC but once it gets like halfway through formatting it fails and gives the error code 60. I have looked at another thread whose CRIO had the same problem and i tried what they did but no luck... We have spent close to 10 work hours trying to figure this out, we tried pretty much everything that has been posted. If any one else has figured this out please let me know through this post or through a PM because we desperately need your help so any input will be appreciated.
Thanks in advance,
Sean
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 06-01-2009, 16:24
TDohse TDohse is offline
AKA: Thomas
no team (NI)
TDohse is an unknown quantity at this point
Re: CRIO Error 60
LabVIEW error 60 is "The specified network address is currently in use". Based on that I'd guess you have some network device configured with an incorrect IP.
Common things to check are that you don't have other network cards enabled on your PC, you are directly wired PC to cRIO port 1 (with crossover cable if your network card is not auto-sensing), and that your firewalls are either disabled or won't block any of the traffic (including udp traffic, traffic to a 0.0.0.0 IP).
Unread 06-01-2009, 16:29
seanl's Avatar
Re: CRIO Error 60
We did turn the fire wall off and we did disconnect from other networks, but we haven't completely turned off the network card. i might try that today ill add that to the list of things to try. any other suggestions?
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 09-01-2009, 04:21
Ray Ray is offline
Ray is an unknown quantity at this point
Talking Re: CRIO Error 60
We finally resolved the problem by
1. Disabling the firewalls & wireless card
-In Vista, Windows firewall with Advanced Security has 3 separate firewalls
-I disabled not only the radio, but also the card itself in the device manager.
2. Formatting the cRIO
3. Re-installing the NI-CRIO 4.2.1? in MAX
4. Connecting to the cRIO via the DS, we had been connecting directly to the cRIO via a crossover cable for a while.
-Don't know if that affected anything, but it finally worked that way.
Unread 09-01-2009, 15:54
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: CRIO Error 60
You also had a wireless card in your PC? I wonder if there is a conflict between using the supplied Cisco/Linksys devices and PC/laptop internal WiFi radios?
Russ
Unread 09-01-2009, 17:30
seanl's Avatar
Re: CRIO Error 60
we feel your joy we just figured it out... it looks like we both did the same thing to get it working.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 10-01-2009, 10:55
landon2345's Avatar
landon2345 landon2345 is offline
AKA: Landon
FRC #2345 (United Entropy)
Team Role: Electrical
landon2345 is an unknown quantity at this point
Re: CRIO Error 60
Our team has had similar problems. While using the imaging tool we come up with an error saying "The specified IP address is unreachable. Ensure that the IP address is on the correct subnet." Could it be possible that the computer we are using (Vista Basic) is searching "online" for the IP address and ignoring the ethernet entirely?
Unread 10-01-2009, 11:00
Re: CRIO Error 60
If you've got your development PC/laptop simultaneously connected to both the robot network AND the internet, you should definitely try disconnecting your internet connection. In an installation that I assisted with, we needed to set the subnet mask of our development PC's robot network NIC to 255.255.255.0 instead of the recommended 255.0.0.0 since the robot network would otherwise "collide" with the rest of our network.
Russ
Unread 10-01-2009, 11:08
landon2345's Avatar
AKA: Landon
Re: CRIO Error 60
"In an installation that I assisted with, we needed to set the subnet mask of our development PC's robot network NIC to 255.255.255.0 instead of the recommended 255.0.0.0 since the robot network would otherwise "collide" with the rest of our network."
How do you set the 'subnet mask' and what is NIC?
Unread 10-01-2009, 12:08
Re: CRIO Error 60
NIC = Network Interface Card (or Controller), this is the hardware adapter in your PC or laptop with an Ethernet port (might also be used to described an internal WiFi adapter? I don't know about that)
On most (all?) Windows PCs, go to Start->Settings->Network Connections and right-click on your LAN connection. Go to the General tab and select the Internet Protocol (TCP/IP) connection -> Properties. This is typically where you set the IP address, subnet mask, whether to use static or dynamic IP addressing, etc.
If you've got an IT person nearby, you might want to ask them for help. The FIRST getting started docs talk a lot about configuring IP addresses but may assume that everyone is already familiar with the above network configuration. Maybe that's a bad assumption.
Russ
Unread 10-01-2009, 12:33
landon2345's Avatar
AKA: Landon
Re: CRIO Error 60
Yeah probably a bad assumption. Okay, thanks for your help!!!
Unread 13-01-2009, 07:41
landon2345's Avatar
AKA: Landon
Re: CRIO Error 60
My team still cannot get the cRIO to update. Still getting error message: "The specified IP address is unreachable. Ensure that the IP address is on the correct subnet." We do not know what the problem is and we will try to get IT help today. We have been using a computer running vista basic 32 bit(dont know if that matters). I have Norton Antivirus so I have been shutting off the firewall and intrusion prevention. On the internet settings in TCP/IPv4 I have set the IP address to 10.23.45.6 and the subnet mask to 255.0.0.0. After trying the imaging we still always come up with the 'error' as seen above.
Any help would be much appreciated
-A pleading cry from all of us here at 2345.
LebView Error -- Error 1055 occured at Property Node in FRC Create Project.vi->FRC Wi RMS11 Programming 8 08-12-2008 18:20
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
