No arms allowed?
8.3.2 General Robot Design
<R11>At the start of, and during, the MATCH the ROBOT shall fit within the dimensions listed below: Maximum Width : 28 inches (71.12cm) Maximum Depth : 38 inches (96.52cm) Maximum Height : 60 inches (152.40cm) Maximum Weight : 120 pounds (54.43Kg) What I get from this is that you can't have an arm reach out of your bot, nor can you be exactly at the weight limit since if your bot does carry a ball than it would be over the limit during the match. |
Re: No arms allowed?
As far as the weight goes, you can be at 120.00 lbs at inspection. Go over 120 lbs and that's a bad thing. The balls do not count towards robot weight; it is the robot, less the official bumpers and battery that get weighed upon inspection. If your robot suspiciously seemed to grow a bit, they might call you back for re-inspection, but the balls are not an issue.
As far as the arm goes, you are correct. You cannot have an arm that extends beyond your bumper zone, as per Update 1 today: Quote:
But then to counter that the balls are not included in the weight there is this from the manual
8.3.2 General Robot Design <R11> .... A. Exception: solely for the purposes of determining compliance with the weight and volume limitations, these items are NOT considered part of the ROBOT and are NOT included in the weight and volume assessment: •The 12V battery and its associated half of the Anderson cable quick connect/disconnect pair (including no more than 12 inches of cable per leg, the associated cable lugs, connecting bolts, and insulating electrical tape), •BUMPER assemblies that are in compliance with Rule <R08>, •The TRAILER, •The OPERATOR CONSOLE. None of that states the game ball, so the Ref could possible call that your bot be weight with balls on it in the middle of a round, putting you over the weight limit (If you ever got that close). I'm not worried about the bot ever getting that close, I'm more worried about the rule stating that we can't have anything reaching out from our bot, stopping us from building an arm. |
The game pieces are not part of the robot weight, I promise. When they weigh you in at inspection, there aren't going to be any game pieces around. These are never considered to be part of your robot. They're always referred to as separate entities, as suggested through the manual, such as in: Quote:
You've still got 41 days and nearly 7 hours until ship; this should be sufficient time to rethink your team's strategy and design. Be creative, but try to think inside the [bumper perimeter] box. Last edited by smurfgirl : 07-01-2009 at 00:21. Reason: added something |
| Shooters vs Arms | ggoldman | Rules/Strategy | 102 | 03-03-2008 19:54 |
| Arms | Evil Asian | Technical Discussion | 24 | 08-04-2007 12:29 |
| Arms anyone? | 6600gt | Technical Discussion | 15 | 10-01-2007 19:23 |
| pneumatic arms | Jesse | Control System | 1 | 06-02-2004 15:41 |
| Arms | mikeL 177 | General Forum | 2 | 19-02-2003 11:15 |
