Help with Timers on PIC18F in C18 (what the 2004-2008 RCs had)
I'm having trouble with this piece of code.
if(sManualUp == 0 && oldManualUp == 1){
mZEnable = 0;
mZSleep = 0;
mXSleep = 1;
mXEnable = 1;
mDirection = 1;
OpenTimer0( TIMER_INT_ON & T0_16BIT & T0_SOURCE_INT & T0_PS_1_1 );
INTCON2bits.TMR0IP = 1;
INTCONbits.TMR0IE = 1;
INTCONbits.GIE = 1;
INTCONbits.PEIE = 1;
WriteTimer0(45535);
}else if(sManualUp == 1 && oldManualUp == 0){
INTCONbits.GIE = 0;
INTCONbits.PEIE = 0;
INTCONbits.TMR0IE = 0;
oldManualUp = sManualUp;
Re: Help with Timers on PIC18F in C18 (what the 2004-2008 RCs had)
Are you sure oldManualUp is intialized? Did you check for nulls? Neither will be true if oldManualUp is uninitialized. sManualUp must be initialized since evaluating it to zero works. Remember that:
variable == Value (any value in cluding zero) will only work if variable is intialized to a value and is non-null. |
Yeah, thats definitely not the issue, it seems that its somehow running away with the interrupts and jumping to strange spots in the code that it manifestly shouldn't be. Its like the program counter (which gets stored when the interrupt service routine is called) is getting corrupted, and then when it goes to exit the interrupt, it jumps to some invalid location.
| Help with Kevin Watson's 2008 code | 2526 | Programming | 6 | 05-02-2008 16:53 |
| Please help. I've had it with this camera | Inverted | Programming | 6 | 14-01-2007 22:35 |
| What are with the Ls in Kevin's code??!!! HELP!!! | RbtGal1351 | Programming | 2 | 18-02-2005 16:57 |
| What type of timers for autonomous? | thoughtful | Programming | 1 | 09-12-2003 02:28 |
| What team had the best human player? | charlie_grr | General Forum | 16 | 11-06-2003 12:20 |
