Go to Post "It's robotics season; I no longer know what sleep is." - StephLee [more]
Unread 07-01-2009, 23:57
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
ball dumpers/throwers types
Our team is discussing the nature of the ball dumping/throwing mechanism and I thought I'd ask you Chief Dephi-ers what you think. The opinions fall into 2 basic camps: 1) dump multiple balls at once using a gravity-feed wide front dumper that allows multiple (2-4) balls to fall out at the same time 2) dump balls serially using a mechanism that forces the balls out quickly (think very slow softball pitcher) and can rotate 180+.
Note that the desired dump rate is "as quick as possible" in both modes.
I think a wide dumper is problematic. You are trying to align a rectangle (the robot) with a circle (the trailer). The point of contact is not an edge but a single tangent point. Any balls dumped left and right of the center of the trailers center point have a smaller chance of getting in the trailer. Plus the surface not only means trouble de/accelerating but also positioning the robot. So I think a directional dumper is important.
Thoughts, discussions, comments?
Unread 08-01-2009, 00:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: ball dumpers/throwers types
We're working on a single ball at a time design. One problem you run into with more than one ball wide, is that they like to get stuck.
Unread 08-01-2009, 00:53
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
While we are still designing the design that I am working on protos for has a wide front, yet conveyer belts on top and bottom allowing it to be powered and multiple balls at once.
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 08-01-2009, 01:50
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Since your dumper is confined to quarters snug as a bug in a rug within the very safe confines of your robot's bumper perimeter, consider, all ye gravity fed dumpers, the minimum horizontal distance the balls must travel to find their way into the trailer promised land - the width of your robot bumper, the width of the trailer bumper, and whatever distance lies between the trailer base's edge and its vertical poles. Perhaps a chasm too great to traverse without additional aid....or perhaps not, with certain frame modifications. Either way, something to keep in mind as you design.
Unread 08-01-2009, 01:52
AdamHeard's Avatar
Lead Mentor
Originally Posted by Travis Hoffman View Post
Since your dumper is confined to quarters snug as a bug in a rug within the very safe confines of your robot's bumper perimeter, consider, all ye gravity fed dumpers, the minimum horizontal distance the balls must travel to find their way into the trailer promised land - the width of your robot bumper, the width of the trailer bumper, and whatever distance lies between the trailer base's edge and its vertical poles. Perhaps a chasm too great to traverse without additional aid....or perhaps not. Either way, something to keep in mind as you design.
That's not necessarily true
Unread 08-01-2009, 02:19
dtengineering's Avatar
AKA: Jason Brett
We finished building our trailer today... if you hit that big centre post with a fairly flat or downwards trajectory and a bit of backspin... it looks like you should score every time.
We've had success shooting the balls 6 to 10 feet just by spinning up an old 8" wheel on a lathe and either dropping the orbit ball on it, or compressing the ball between the wheel and a sheet of plywood.
So I'm thinking one ball at a time, but reasonably rapid fire, similar to 2006.
Jason
Unread 08-01-2009, 07:49
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
We did about the same thing, but we really just took the big CIM off of our 2006 robot (of course, we won't be using the big CIM...). A problem that I'm seeing right now just because of how the polycarbonate we're using guide the ball down, and with the shaking of the motor being mounted by 1/16" aluminum or something along that lines (might be thinner), the feeding will have to be centered, otherwise the motor may slow down a little bit. We've even had it jam before.
Unread 08-01-2009, 08:02
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
why not just build two harvesters and run one in reverse?(HINT HINT)
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 08-01-2009, 11:42
MrForbes's Avatar
AKA: Jim
Thanks, Jason, as usual you prototyped our design for us, and found a way to make it work
Unread 08-01-2009, 11:46
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Jason
How much does your completed trailer weigh?
Unread 08-01-2009, 11:59
omgapirate's Avatar
omgapirate omgapirate is offline
FRC #1676 (Pascack Pioneers)
Team Role: Electrical
omgapirate is an unknown quantity at this point
One of the ideas that we were considering was an active dumping system which is to say instead of relying on gravity to do our dumping we will have a a dumper which can propel the balls into opposing trailers. Also we will be able to control the dump in case the opponent manages to move out of the way. The design includes two barrels which should increase the rate of fire. It's an early desgin concept that still needs fine tuning but we fell we could take it somewhere.
Unread 08-01-2009, 14:07
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Jason
Man, we have a lathe and everything... our students took alot of time to build a roller setup out of 80/20 scraps and a 2008 KOP wheel. The lathe idea is a great idea so we can figure out what rpms to set the spindle motor to!
Our design isn't simply a wheel though, it will be a roller that's 4" wide (or a 1-2" diameter wheel that's 4" wide, however you look at it). I'm also toying with the concept of making it a sort of conveyor design so that the moonrock has more acceleration time. Thoughts?
GitHub
Unread 08-01-2009, 14:12
run the trap!!!
Team Role: Human Player
Originally Posted by wireties View Post
...Any balls dumped left and right of the center of the trailers center point have a smaller chance of getting in the trailer...
This hasn't been my experience. In fact, I've found it to be quite the other way around.
It's much easier to shoot downwards on either side of the big pole and make the shots. If you aim for the pole they just bounce off...
As for static mechanisms, like dumping.... Its just always been my experience that if you don't force the game pieces to do what you want they usually won't do it
-Philip J. Fry
Unread 09-01-2009, 17:02
JKWarrior's Avatar
JKWarrior JKWarrior is offline
FRC #0573
JKWarrior is an unknown quantity at this point
Dumping multiple balls at once isn't practical. feed the balls one or two at a time would be better, but then the dumper jams easier
Unread 09-01-2009, 17:14
GBilletdeaux930's Avatar
GBilletdeaux930 GBilletdeaux930 is offline
AKA: Greg
FRC #0930 (Mukwonago Bears)
GBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to all
Can anyone post a video of the shooting so that i can show my team?
Thank you.
Special grappling hooks for throwers? ShadowNinja General Forum 3 04-01-2009 17:48
Gear Types Joe_Widen Technical Discussion 16 02-06-2006 11:46
how effective are the herders/dumpers? Mullen General Forum 46 03-04-2006 21:25
Attachment Types russell CD Forum Support 6 24-02-2005 10:12
Music types Carolyn Duncan Chit-Chat 42 03-08-2001 23:06
