Go to Post Not gonna lie, I wanna marry the person over at #254 who does their wiring... I have admired it for years. :) - Lightfoot26 [more]
Unread 08-01-2009, 18:26
Emily M. Emily M. is offline
FRC #0694
Emily M. is an unknown quantity at this point
Do we have to update firmware?
Hi,
Our team just received the cRIO in our kit of parts on kickoff. We were wondering if we still need to update the firmware on the cRIO and the ds, or if it would have been updated before we received it. Thanks for your help!
-Emily
Unread 08-01-2009, 21:05
Re: Do we have to update firmware?
You need to update them yourself. Nobody will have done it for you. They almost certainly still have the factory-loaded software image on them.
Unread 08-01-2009, 21:45
Electrical Engineer
Rookie Year: 1995
Emily,
Your team should start by following the step by step instructions outlined in Chapter 1 here. This "acceptance test" requires the factory software. Please do this before you attempt any software upgrades.
As you proceed, you will very likely encounter problems. Have a team member search these fori to help you solve your issues. With over 1800 teams all using a new control system, I can almost guarantee that any issue you may have has already been experienced by others.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 09-01-2009, 16:52
landon2345's Avatar
landon2345 landon2345 is offline
AKA: Landon
FRC #2345 (United Entropy)
Team Role: Electrical
landon2345 is an unknown quantity at this point
Can someone tell me how to update the cRIO? Because we cannot even find the file for the update. Where is it at?
Unread 09-01-2009, 17:03
Both the update and instructions are in the "Software Updates" section at:
http://www.usfirst.org/frccontrolsystem
Unread 09-01-2009, 17:36
landon2345's Avatar
AKA: Landon
Well noted. We are aware of that but are unaware of how to obtain a new cRIO image. We need FRC_2009_V2 or above for the cRIO update. We currently only have V1.
Unread 09-01-2009, 17:38
Same place.
The cRIO image V7 comes as part of the "LabVIEW FRC software update" -- LabVIEW Update 2
When you install, the update V7 appears in the FRC cRIO Imaging Tool choices.
Unread 09-01-2009, 18:34
landon2345's Avatar
AKA: Landon
okay so we have managed to find v7 but still have a problem. the imaging tool starts off okay but after 40 seconds or so it says "The specified IP address is unreachable. Ensure that the IP address is on the correct subnet."
driver station firmware update bobbyt14 Programming 15 14-02-2009 15:05
Driver Station firmware update failure ofshea FRC Control System 8 13-01-2009 11:35
Firmware update Cuog Programming 2 21-02-2006 20:28
Camera doesn't have firmware? no programming? GraphicArtDesig Programming 6 19-01-2006 20:10
Team Update #13: Where's The Firmware? Astronouth7303 Programming 0 24-02-2004 19:25
