Go to Post Don't let your FIRST blinders prevent you from thinking. - JaneYoung [more]
Unread 08-01-2009, 18:57
Jill Jill is offline
FRC #2197 (Las Pumas)
Jill is an unknown quantity at this point
Wireless mode
Everything is hooked up according to the manual. The bridge is set to 10.21.97.1 and the router to 10.21.97.4. My laptop is 10.21.97.6. When we try to run it wirelessly, it doesn't get a signal. All the settings for the router and bridge are exactly how the manual describes. Is there a way to change the IP address of the driver station, or does it happen automatically? Any ideas?
Unread 08-01-2009, 20:09
Geekzilla201 Geekzilla201 is offline
Alumni/Volunteer
no team (Bob's Builders in Black)
Geekzilla201 is an unknown quantity at this point
Re: Wireless mode
Have you set your team # in the driver station?
Computer Science House - Rochester Institute of Technology
Unread 08-01-2009, 21:04
Re: Wireless mode
Yes, team number is set in the driver station
Unread 08-01-2009, 21:35
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: Wireless mode
Is the bridge set to connect to the router over the wireless?
Unread 08-01-2009, 22:58
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: Wireless mode
What is not connecting? Is it the laptop or the game adapter on the robot?
Unread 08-01-2009, 23:22
Re: Wireless mode
This happened to us tonight...check ALL security settings on the router and game adapter and see what happens.
Unread 09-01-2009, 11:53
techsupport07's Avatar
techsupport07 techsupport07 is offline
FRC #0876 (Thunder Robotics)
techsupport07 is an unknown quantity at this point
Send a message via ICQ to techsupport07
Re: Wireless mode
You do not need the drivers station number to be set to work wirelessly. However, the manual does skip a step in setting up the wireless connectivity. We, too, had trouble getting it to work wirelessly. Everything worked perfectly tethered, but we would set up for wireless and it did not work (seemed like router and gaming adapter were not communicating). I then started to mess around with the router...later found out that the router (at least ours did) came out of the box with WPA security enabled. If you disable that security, it will work perfectly. I don't think the manual mentioned anything about having security on or off, but I wouldn't think we would need the security. If we do need the security on, please someone reply and let me know...
Wireless settings IndySam FRC Control System 2 24-11-2008 15:19
Wireless Gamepads lazyxninja Control System 1 27-01-2007 15:35
2 Wireless routers MattK Chit-Chat 7 02-06-2004 20:46
2 Wireless routers MattK IT / Communications 0 02-06-2004 06:30
Wireless Camera? XRaVeNX General Forum 4 08-02-2002 19:54
