Floor Problems
Hi
Our team has been testing with the "Regolith" floor and the tires. When the robot is held in place the tires spin in one place on the floor and the floor then produces a powder(white) and the tire surface is damaged. Anyone else have this issue?? thanks in advance |
Re: Floor Problems
We noticed the same thing. Not only is the surface of wheel "roughened", the surface of the FRP is worn down. Over time, the friction coefficient increases. Early matches will be very slippery, but as competition goes on, grip will improve....in spots.
Re: Floor Problems
I was surprised in how the coefficient of friction changed as the wheel's wear. We started Sunday on a clean school floor and measured a coefficient of 0.095 (static) and 0.085 (dynamic). We figured this would be closed enough for testing purposes and kept our practice bot light to make up for the higher coefficients. After about 10-15 minutes of driving around during the first few days of the week, we remeasured the coefficients, they're up to 0.18 (static). We now have some FRP material and get 0.11 (static) on it with our worn in wheels. What is causing a lot of the wearing in the wheels is any dust and dirt on the floor. I absolutely believe that as the floor and wheels wear in, the traction will get slightly better, but still nothing compared to previous years.
Re: Floor Problems
Wow, thanks for the heads-up. Does anyone know if doing this (accidentally) will be penalized as damaging the arena?
Re: Floor Problems
I noticed this happening as well, however, only after having driven for a while on our 4' x 8' sheet of FRP then driving on the carpet. The wheels seemed to leave a dust-like residue on the carpet.
We drove pretty carefully, since the sheet was so small, and only for a couple of minutes. FIRST is usually very judicious about what they penalize based on field damage. I think the intent of that rule is to avoid blatant, intentional damage to the field pieces. |
Re: Floor Problems
When they mean "damage to the field" they usually mean anything that causes actual fractures to the carpet/tile or basiclly anything that needs to be fixed beyond a small bit of duct tape to the floor.
But I wonder if the GDC knows that the floors get roughed up? I wonder if each regional gets new flooring? Maybe a Regolith Resurfacer "Zamboni" will pass over the field every so often? |
#7
Re: Floor Problems
FIRST isn't going to replace the floor after every regional. They wouldn't replace the carpet in the past and it was cheaper, their certainly not going to replace $1200 of flooring.
Think about the third or forth regional on a used floor or even better think about the championship after division finals on worn out floors teams come to the pristine field at Einstein. |
#8
Re: Floor Problems
The question would be....What happens for the off-season events? Will FIRST be supplying the flooring with the field, or do the events have to find their own? |
#9
Re: Floor Problems
Joey |
#10
Re: Floor Problems
thanks for the heads up, we haven't done this kind of thing yet but i'll be sure to pass it along....
#11
Re: Floor Problems
Thanks for the advice, this will come in handy when it comes to our game strategy....
#12
Re: Floor Problems
So we've been driving around for a few days as well and now have a bunch of powder that's accumulated. Is it being overly cautious to be concerned with the combination of "powder" coming off of something "fiberglass" for 6 weeks???
Installation Safety: "Wear filter mask to cover nose and mouth, especially when cutting." MSDS: Section 7 Special Protection Information Respiratory Protection (specific type) NIOSH Approved Protective Mask That Covers Mouth and Nose When Cutting or Machining. Ventilation Control Dust When Cutting or Machining Protective Goves Dust/Abrasive Resistant Eye Protection Safety Glasses or Goggles Other Protective Clothing or Equipment N/A Hopefully I'm making a mountain out of a molehill... |
#13
Re: Floor Problems
I wonder if FIRST knows about this erosion of the playing field.
| HDPE or ICE FLOOR | R.C. | Rumor Mill | 60 | 23-01-2009 23:38 |
| Slick floor Burnouts | Wayne Doenges | General Forum | 0 | 08-01-2009 18:17 |
| Floor Damage? | BHS Bucs | General Forum | 8 | 09-02-2008 07:25 |
| UnEven Floor??? | sgsdragons | Technical Discussion | 18 | 23-01-2006 18:52 |
| floor protection | Ken Leung | Off-Season Events | 15 | 17-05-2003 07:42 |
