Wheel Wear
ok so we are all going to test our bots. Some of us dont have the field surface and we may be practicing on our shop floor. soo heres my questions
how do yall think first will deal with worn wheels due to testing? |
Re: Wheel Wear
In the rules it says <R06>"The surface tread of the ROVER WHEELS may not be modified except
through normal wear-and-tear." |
Re: Wheel Wear
I'll also direct you at <R06>
"The intent of this rule is that the ROVER WHEELS be used in as close to their “out of the box” condition as possible, to provide the intended low-friction dynamic performance during the game" Anyone hoping to wear their wheels before the competition as an advantage for traction needs to give themselves an ethics check. FIRST rules, as we all know, are about intent, not lawyering. In your case, it might be unavoidable wear and you might not have the budget to replace the wheels. However, if you know wheel wear is going to be an issue, pick up some more if you can to comply with the intent of the rule. |
Re: Wheel Wear
haha gotcha... man i need to change my train of thought. in FSAE racing, its allabout bending and pushing to rules to get MAX performance lol
hmm, we only have our shop space to run. Now its not as rough as sidewalk concrete but its not the smoothest surface ever. And i know ALOT of teams that only have a parking lot to run... ![]() |
lolz you could wear your wheels down so its really rough and you would gain a bit of traction but not much...
But this really a techicality... so if you do this you can get skrewed over by the judges... and have to switch wheels, so... idk |
Re: Wheel Wear
I'm sure what ever u guys are doing will be considered "normal" but if ur planning on some intense driving practices u probably could order more wheels just to be safe.
#7
Re: Wheel Wear
If you guys want a good surface to test on, I suggest some clean tile flooring that is in most schools inside. We had a sample of off-brand regolith and compared it to our tile flooring and got similar numbers.
I see no reason why a school wouldn't have tile somewhere. If it's an issue of "there's other people there", just wait until after they've left and then go use the room. Just make sure to leave it in the same condition you used it in -- wouldn't want to get in some trouble because you messed it all up. ![]() |
#8
Re: Wheel Wear
If you are trying to wear your wheels for more traction at a competition: good luck! You will more than likely wear one more than the others, which means one of the wheels probably will not touch the surface. On top of that, it's fairly difficult on this field to keep all four wheels with the same amount of traction if you modify them. (A mu difference of 0.01 with these wheels is a +- 20% amount of traction...)
So, 'normal wear and tear' from your shop -- I wouldn't worry about too much. I'd imagine that the GDC expects that everyone will want to practice ahead of time and that not everyone has an ideal field to do so. |
#9
Re: Wheel Wear
Re: Wheel Wear
I have to take issue with your "Skrewed over" comment. The judges and refs are there to uphold the rules not Skrew people over. As a matter of fact I find them to be very helpful to teams that don't satisfy the rules. |
#11
Re: Wheel Wear
This will more then likely come down to the head inspector (in many cases) at the regionals/Champs. "Normal wear" in my book, is light scratching of the tread area, that would resemble a razor slit. There should be very few side to side "slits" and a fairly constant diameter slit. These slits will be hard to be done without testing, because as some have found out, the slits tend to be spuratic and very inconsistent on the tread of the wheels. In a nutshell, I believe the only issues that inspectors will have, is with team who have altered their wheels, gracious professionalism will need to be used by teams to make sure that they do not alter their wheels to appear "more used" then normal.
#12
Re: Wheel Wear
1885's own example: In Atlanta '08, on Friday a ref (who was also an inspector on Thursday) noticed an angle connection on our radio modem serial port. We put our controller 1.5" from the rear of the robot. No big deal we thought, since we could put an angle on the radio modem connector and connect the radio while staying within the dimensions. Little did we notice that the connections themselves were not allowed to be modified in ANY way, which the ref pointed out to us with the rulebook. We made it through 2 regional competition inspections and Atlanta inspections without a single word to us, so our plea to the head ref in Atlanta was for us to keep the angle connector on. His compromise in return was that we were not allowed to dispute a match in which our robot stopped responding due to communication issues, as was his interpretation of the intent of the rule. We were allowed to compete if we agreed, which we did. Believe me, we're triple checking our compliance with the specifics this year! |
#13
Re: Wheel Wear
well for testing we had a good idea of a hockey areana.. but we are kinda in Canada so they ant soo hard to find up here.
#14
Re: Wheel Wear
I have a serious problem with some of the logic presented in this thread. A true FIRST student would hear that the wheels gain traction as they wear, and rather than thinking pushing the rules to the max, they'd see that this REALLY means. Folks, design your robots to allow easy swapping of wheels. If FIRST sets a max amount of wear, you don't want to have to take your entire robot apart to change out a few wheels.
#15
Re: Wheel Wear
We have not tested our wheels out yet on the Robot but i really, really hope the wheels do not wear down as quick as people say they do. First is expensive enough with out have to have a ref demand you change your wheels out every regional.
| Wear Sunscreen | Herodotus | Chit-Chat | 1 | 18-05-2008 18:22 |
| Tread Wear | RyanN | Technical Discussion | 21 | 09-11-2007 22:18 |
| Wheel wear??? 6" Pneumatic tires??? | Scott358 | Technical Discussion | 11 | 29-03-2003 13:35 |
| I wear eye glasses... | archiver | 2000 | 3 | 23-06-2002 22:32 |
