help me in LabView code
hello
our team is started to program with labview ... but there is some problems .. we tryed the simple code (tank or arcade) that came with labview ... and we deployed it on our CRIO ... there is no problems everything works well ... the problem that we don't know how to change something in the code ... for example ... add more victors and more than 1 joystick ... is there someone could help ?? or give me guide how to change something in the code and how to add something ??!!! i am still begainer ... and if we didn't learnt labview we have to go windriver ... but i hate c/c++ programing ... so please help rapidly |
Re: help me in LabView code
http://www.usfirst.org/community/frc....aspx?id=10934
There's some guides and help under Software Documentation. It should help you get started. Getting Started with LabVIEW for FRC LabVIEW Robotics Programming Guide for FRC LabVIEW FRC Help Document Using the LabVIEW FRC Framework If you have any questions don't hesitate to ask. |
Hi there!
I would also recommend looking at the stuff that NI has put together for us: http://www.ni.com/first In particular take a look at the FRC Getting Started Tutorials, here's a link: http://decibel.ni.com/content/docs/DOC-2511 I found a lot of that stuff pretty good. There is certainly a lot of material there. Here are a couple of the things I found particularly helpful in understanding how things work and how to modify the defaul code (or "framework") that came with the DVD. - The "Robotics Library" video - The "Using Framework" document are probably good places to start Also take a look at the "Basic Motor Control" That should keep you busy for a few hours, but they should be well worth it. One last thing, if you are totally confused by the concepts of VI's, front panel, block diagram, while loop, wires, terminals, etc (all the LabVIEW terminology), then you may want to go through the Getting Started with NI LabVIEW tutorials. Here's a link: http://zone.ni.com/devzone/cda/tut/p/id/7466 These tutorials have nice videos and exercises that make them easy to follow, but keep in mind that these are designed for learning LabVIEW in general (so the examples are not designed for the FRC cRIO robot controller). I hope this stuff helps... Good luck! David A |
The tutorials the Ben has on his site are really great.
http://www.lvmastery.com/tipjar2008 Some are general LabView and some are directed specifically at FRC. |
| Posting LabView Code Easily? | Greg Marra | NI LabVIEW | 17 | 25-11-2009 16:49 |
| LabVIEW Error Code 1055? | Vince | FRC Control System | 11 | 29-11-2008 09:32 |
| Team 39, 2008 LabVIEW Beta Code | BornaE | General Forum | 17 | 10-10-2008 17:21 |
| Configuring Labview code to easyC | team877 | LabView and Data Acquisition | 6 | 16-01-2007 09:21 |
| LabView Gear Tooth Sensor Code | SkiRacer | LabView and Data Acquisition | 2 | 17-01-2006 03:53 |
