[FTC]: Lego Motor Extension Cord?
Hello,
We have a LEGO motor sitting at a considerable distance from the NXT and we need a longer cord than provided in the kit, does anyone have a way to create a long distance connection? Thank You |
Re: [FTC]: Lego Motor Extension Cord?
One thing that we did was use some of the interface cables from the NXT to RCX cable. You can take two of these cables and combine them at the RCX connection and make a very long cable. If the cable is longer than that that you need, you might want to move the NXT closer to the motor in question.
You can get the cables here Also, HiTechnic sells "Extra long cables", You can find the at the bottom of this page I hope this helps out. Regards, ~FTC #1, Team Unlimited Last edited by gdo : 10-01-2009 at 18:59. |
WOW THANKX!!!!. I'm not sure if we can use the extended set, but i'll ask on Q and A forum, and the RCX trick is greatly appreciated.
| [FTC]: Random Error with FTC motor control | Xaphiinia | FIRST Tech Challenge | 2 | 01-12-2008 15:39 |
| [FTC]: Conveyor Belt Lego Parts | Shimoniskey | FIRST Tech Challenge | 7 | 18-11-2008 19:58 |
| [FTC]: Lego Axle Question | ttldomination | FIRST Tech Challenge | 3 | 05-11-2008 09:29 |
| [FTC]: FTC Servo-Motor Problem with Labview | dnhansen | FIRST Tech Challenge | 1 | 26-10-2008 00:43 |
| [FTC]: [FTC] Motor Controller problems | michael714 | FIRST Tech Challenge | 4 | 14-10-2008 00:33 |
