Go to Post IRI seeks to invite the very best robots to play the FIRST game, achieving the highest level of play, while keeping in place the FIRST atmosphere. - Nathan Streeter [more]
Unread 10-01-2009, 18:19
ironbears ironbears is offline
Alex@854
AKA: Alex
FRC #0854 (Ironbears Team 854)
ironbears is on a distinguished road
Broken cRIO
Hey today team 854 the Ironbears have relized after 3-4 hours of testing that our cRIO is broken. we heard a faint buzzing noise from the cRIO. we immediatly shut off power and disconnected everything but power. the noise still buzzed. we sent off an email to karen rosenthal (canadian teams know who she is) any ideas what messed up. wiring is fine signals are 100%.
help is most appreciated
Iron Bears Team 854
Rookie Year 2002
2008 ON Xerox Creativity
2007 WAT Rockwell Automation Innovation in Control
2007 WAT Regional Finalist
2007 ON Motorola Quality
2007 ON Regional Finalist
2006 ON Motorola Quality
2005 ON RadioShack Innovation in Control Award
2005 WAT RadioShack Innovation in Control Award
2003 ON Delphi "Driving Tomorrow's Technology"
2005 The Championship Event (4/21/2005 - 4/23/2005)
2003 The Championship Event (4/10/2003 - 4/12/2003)
Unread 10-01-2009, 18:44
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Re: Broken cRIO
Are you sure the buzzing noise isn't coming from the Power Distribution board?
Typically, this type of noise is heard from ringer circuits boosting a voltage up from say 12V to 24V.
There was mention of this in the controller chapters. If the cRio lights correctly, and performs correctly, (you can use the serial out to verify correct boot sequences) then there may be nothing wrong at all.
Team MARS = 1.523 AU from the SUN
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 10-01-2009, 21:28
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Re: Broken cRIO
Is the cRIO acting normal other than the buzz? Is the buzz loud (can you hear it from a couple of feet away?).
Buzzing can come from the internal power supply when it current limits or when it is "starved". If you have a multi-meter, can you please check the voltage across the supply input to the cRIO?
Unread 10-01-2009, 22:35
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: Broken cRIO
What do the status lights say?
Does it get an IP? Try a null modem to the serial port.
Are you sure it's the cRIO? The PD does buzz.
The cRIO needs between 19 to 30V. Check to see if the wires are providing it between those limits.
If you do end up sending it it, I believe they send you one as soon as possible and you send the cRIO back, opposed to you sending it in and having to wait a long time.
I find it hard to believe that you truly broke it. These things can take a beating. Didn't they throw one off a building (while collecting accelerometer data) and have it survive?
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 11-01-2009, 09:53
AKA: Chris Rake
no team (Athena)
Re: Broken cRIO
Yes, a 9 story drop
Unread 12-01-2009, 18:14
Alex@854
AKA: Alex
Re: Broken cRIO
turns out that the wirless systems dont work when battery is lower than 30%
Iron Bears Team 854
Rookie Year 2002
broken ir input Yamis Programming 2 08-02-2008 11:05
Broken O/I NumberQ Robotics Education and Curriculum 10 01-10-2004 16:06
Broken robots Tytus Gerrish Technical Discussion 12 29-09-2004 20:46
CD is broken. Rickertsen2 CD Forum Support 62 26-10-2003 13:06
Broken promises or BROKEN ROBOTS! archiver 1999 9 23-06-2002 22:18
