C++ code terminates instantly
In windriver in debug mode it either gives memory access error or terminates. We have completed the benchtop test, and believe cRIO and driver station are updated.
Any ideas? Driver station reads DS : 2008-10-29a (even though update was labeled nov 1st) |
Re: C++ code terminates instantly
It might be one of these:
1) did you "undeploy" the running program before downloading? 2) did you set it to "Automatically attach spawned kernel tests"? (that's in the debug options in the menu when you right-click the project in the project explorer window) Either of these may cause that problem Also, the update was labeled nov. 1st, but that is the correct info in the display - ours also read that and is updated/operational Last edited by Ryan O : 01-11-2009 at 12:37 PM. Reason: Additional Information |
| Problems integrating CMUCAM code and IFI Default Code | Windward | Programming | 2 | 02-06-2007 04:48 PM |
| how to convert Easy C code into real code? | TheHolyLancer | Programming | 1 | 01-29-2006 09:09 AM |
| problems using gyro/adc code with camera default code | tanstaafl | Programming | 7 | 01-22-2006 11:09 PM |
| Team THRUST - Kevin's Code and Camera Code Combine | Chris_Elston | Programming | 3 | 01-31-2005 10:28 PM |
| Chat Instantly - Florida <=> South CA <=> Boston NOW! | soap108 | General Forum | 26 | 06-03-2003 11:43 AM |
