Go to Post Guys wearing pink, that strikes fear into my heart now :). - Cyberguy34000 [more]
Unread 11-01-2009, 00:02
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
'Regolith' Concern?
Disclaimer: I am only looking for more information in this thread.
Anyway, so we have all been playing a bit on the 'regolith' surface. We ran our robot on it, checking the frictional forces. The surface was easily either burned or disintegrated when the wheels would 'spin-out'.
We smelled something funky, burning plastic smell, no big deal right?... I hope not...
I have to say that the smell reminded me a lot like the smell of styrene. The panels are some sort of glass fiber composite. The 'Glasliner FRP' is a polyester resin composite. Polyester resins can be dispersed in styrene before curing (haven't looked into it yet).
I am concerned because styrene is not exactly a very safe material. You can read an MSDS if you would like to know a little more information on styrene.
Styrene has a very pungent aroma, detectable by our senses in ppm, so just smelling it is not necessarily dangerous.
I am wondering if any research has been done on the matter or if anyone else knows a lot about the 'regolith' material. Have I misdiagnosed the aroma? Not only was there a smell, but a fine particulate as a result of the friction.
I doubt FIRST would allow any harmful materials to be used in competition. They also mentioned that these two materials are used to simulate driving on the moon, i.e. I assume that these materials have been tested under conditions like in the competition prior to this years game.
Please respond in this thread or in PM if you are knowledgable in this area. Like I said, there may not have been any styrene involved at all, burning plastic can have all kinds of weird smells. Thanks.
Good Luck teams, the game looks like fun.
Cold Fusion's 10th Season
Unread 11-01-2009, 01:46
Woodworker88 Woodworker88 is offline
Shop Rat
AKA: Michael Fagan
FRC #0190 (Gompei and the H.E.R.D), FRC #0114 (Eagle Strike)
Woodworker88 is a jewel in the roughWoodworker88 is a jewel in the roughWoodworker88 is a jewel in the roughWoodworker88 is a jewel in the rough
Re: 'Regolith' Concern?
I believe that the surface of the Glasliner FRP material is primarily fiberglass and therefore any mechanical abrasion is unlikely to result in the release of styrene fumes. Considering the material is designed for use in bathrooms and other common locations, any outgassing is possible but unlikely.
Based on my observation of the dust produced under intense load, I believe it is a mixture of fine fiberglass particles (potentially irritating but unlikely to be toxic in small amounts), plastic particles from the rover wheels, and dirt from various surfaces.
2005-2008 FRC Team 114 (Los Altos, CA) Lead Machinist and Shop Manager
2009-Present FRC Team 190 (Worcester, MA) Lab Manager
Worcester Polytechnic, Mechanical Engineering 2012
2009 Boston Regional
GM Industrial Design, Regional Champs (thanks 61 and 1099)
"Do or do not. There is no try." -Yoda
Unread 11-01-2009, 01:56
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
We had the same problem with the fine particles released, which showed robot tracks all over the carpet Those wheels take the bumps right off that Glasliner
Unread 12-01-2009, 14:35
AKA: Mike
It is a fiber glass composite. Surprisingly, my concern isn't about the fine particulate fiber glass. The continuous phase of the composite is polyester resin. Polyester can contain benzene pendant groups likely from a styrene solvent. When burned, or even ground into particulate, the components go airborne.
The material is used in household and industrial applications because it is mildew resistant, tough, hard, easy to clean, and chemical resistant. That doesn't mean that it is harmless. After all, how often is the wall of a bathroom or the ceiling of a kitchen going to be abraded the way that these floors will during this competition? In any case, the manufacturer highly recommends that you wear masks while cutting or sanding the Glasliner FRP.
Like I said, ppm isn't going to harm anyone, but it can be nauseating or irritating to the sinuses, throat or lungs in the very least. I would just like to verify that this isn't the first time that this issue is being addressed.
Unread 13-01-2009, 09:13
Carol's Avatar
Carol Carol is offline
FRC #0365 (MOE)
Carol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond repute
There is another thread on this topic, which I can't take the time to search for now. But I attached the following MSDS sheet there as well, which I got off of a supplier's website:
http://www.sbs-frp.com/products.htm
It is vague about the type of polymer used, but my guess it that it is a polyolefin mxture, probably polypropylene. But that is just my guess, I am not an expert on this material.
MOE 2007 Chairman's Video by MOE video team and Paul Lazarus http://moe365.org/CHMN_AWD_video_2008.php
MOE 10-Year Video Celebration on YouTube http://www.youtube.com/watch?v=ETcSMUBUqEs
Unread 13-01-2009, 09:18
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
The thread in question is here.
Regolith: Which way? Ragnarokae General Forum 2 10-01-2009 12:43
Crab Steering on Regolith Dan2081 General Forum 33 09-01-2009 16:35
Tell me more about the regolith coating. Michael Hill Technical Discussion 24 09-01-2009 09:36
Home Depot Regolith Part Numbers samepstein General Forum 11 07-01-2009 11:09
Noteable Concern. archiver 2000 5 23-06-2002 22:05
