Go to Post Andy Baker can legally touch the Red and Blue Carpet simultaneously. - Taylor [more]
Unread 12-01-2009, 11:23
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
12.75:1 enough?
Okay, I was working with some numbers and this is what I came up with for a 2 CIM drive (1 driving each side of the robot).
Torque supplied by 1 CIM at peak efficiency = 0.48 N m = 4.25 lbf in.
Torque supplied by 2 CIMs = 4.25 * 2 = 8.5 lbf in.
Max. Frictional Force = [150 lbf (robot) + 40 lbf (trailer)] * 0.2 (rounding the COF up quite a bit) = 38 lbf.
Max. Torque = 38 lbf * 3 in (wheel radius) = 114 lbf in.
Torque needed/Torque provided = 114/8.5 = 13.4.
A toughbox provides a 12.75:1 reduction. Does anyone think that this will be sufficient for powering a robot?
Unread 12-01-2009, 11:38
Jared Russell's Avatar
Taking a year (mostly) off
Re: 12.75:1 enough?
The maximum frictional force is not 150lbs + 40lbs. The trailer wheels are not powered and so don't add to your maximum tractive force. The tongue weight, however, will help you - let's call it 10 lbs (probably an overestimate). So your downforce is 160lbs.
This means that the maximum tractive force (with 0.2 CoF) is .2*160lbs = 32 lbf.
Max torque = 32lbf * 3in = 96 lbf*in
Torque needed/torque provided = 96/8.5 = 11.3
And realistically the CoF is 0.1 or below, so I think direct drive off the ToughBoxes provides more than enough torque (with 1 motor per side).
Unread 12-01-2009, 11:43
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: 12.75:1 enough?
Retired Starman built a competition type trailer and measured the weight (35 lbs), and the tongue weight (5 lbs).
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: 12.75:1 enough?
You should take a look at the motor curves, you'll almost never be running your CIMs at peak efficiency. It's better to look at 50% stall (peak power) and 25% stall, which is where you'd like your motors running most of the time.
50% Stall torque = 2 x 21.5 lbf-in x 50% x 12.75 = 275 lbf-in.
25% Stall torque = 2 x 21.5 lbf-in x 25% x 12.75 = 137 lbf-in.
So I think a 2 CIM drive with the stock transmissions and a 1:1 sprocket ratio will work out just fine. Especially as you won't be getting the full 40 lbs out of the trailer, and the CoF isn't .2
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: 12.75:1 enough?
I was thinking more of a 8-9:1 Ratio with one motor per side. But thatz just me.
R.C.
MadTown Robotics Team 1323
Is 12 hours enough? Heretic121 Technical Discussion 15 29-03-2006 09:28
pic: Close enough? S.Nickens Robot Showcase 11 12-02-2005 00:34
Is PBasic enough or not punarhero Programming 2 05-03-2004 07:59
Enough with the bumpers! archiver 2000 2 23-06-2002 22:32
Enough already... Gui Cavalcanti Rules/Strategy 3 08-04-2002 09:35
