Go to Post Engineering is NOT manufacturing. .... It is good to be able to fabricate things with your own hands, but thats not what engineers do. - KenWittlief [more]
Unread 13-01-2009, 22:55
eNyoron eNyoron is offline
Captain, Programmer, Clueless.
FRC #1787 (untitled.txt (as of now))
eNyoron is an unknown quantity at this point
Send a message via AIM to eNyoron
Anyway to do a soft/quick reset to access a newly uploaded program faster?
I have a couple of questions in regards to the resets that are required to run a program just uploaded to the robot's control panel. Our team is using the 2009 kitbot parts and WindRiver/C++, if that's important to the reset process.
1) Does the robot itself have to be turned off then back on (or can I leave it on and just reset the control panel?)
2) Is there a better/faster way to reset the control panel than simply unplugging and replugging the A/C adapter?
Unread 13-01-2009, 23:46
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
Re: Anyway to do a soft/quick reset to access a newly uploaded program faster?
If by "control panel" you mean the cRio. 'cause I know that I have the cRio hooked up via the serial to the computer and then have hyper terminal up, and just type "reboot". This reboots ONLY the cRio and it goes through a full boot cycle. And you can find how to setup hyper terminal with the cRio in section 5 of the control system documents.
Unread 14-01-2009, 00:01
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Look closely at the cRio, near where the power plugs in. There's a tiny black button labeled "reset". You can press this (probably with the tip of a pen, or a small screwdriver) to reset.
Alternatively, you can connect to the console and type "reset". For more information on this, see section 5.4 of the Control System Manual.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
RC remote program and reset button schematic Bluephlame Electrical 5 10-02-2008 01:24
FRC: Reset and Program Controls yanksrock777 General Forum 4 24-01-2007 22:37
Program error after controller reset randomperson Programming 6 04-01-2005 23:31
Robot Reset Under Program Control? Dan Programming 5 29-04-2003 19:49
How Do I Program My RC To Spot One wheel From Going faster than the other Kyle1010 Programming 5 12-01-2003 15:30
