Go to Post I think everyone just needs to chill out and realize what the real goal of FIRST is. - Koko Ed [more]
Unread 15-01-2009, 19:12
bluebird bluebird is offline
FRC #1782
bluebird is an unknown quantity at this point
how many people have had failing jaguars
I need to know so to make a decision on whether or not to use them. I've read atleast two people had them burnout.
Unread 15-01-2009, 21:07
SWIM's Avatar
SWIM SWIM is offline
SomeoneWhoIsntMe
AKA: James Meintjes
SWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really nice
Re: how many people have had failing jaguars
My team killed ours by wiring them improperly. So, try to avoid doing that if you use them.
alumni of
FRC teams 1489 and 3060
OCCRA teams 2 and 3060
built the current OCCRA placebo
Unread 15-01-2009, 21:23
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Im not sure what we did to ours, but they weren't working properly. We couldn't go backward, and all the wiring was working perfectly before.
Unread 15-01-2009, 21:25
DonRotolo's Avatar
Back to humble
FRC #0832
Ours still work fine.
Unread 15-01-2009, 21:41
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Haven't had a problem with them yet! They're much better than the Victors were for the past few years; the robot is much more controllable.
Unread 15-01-2009, 23:26
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Jaguars do make driving your robot much more controllable at low speeds. This also could be due to the joysticks are more precise than analog joysticks.
One thing to remember is that the Jaguar size is twice as large than a victor footprint. If price is important , Jags are half the price of victors.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 16-01-2009, 00:03
wt200999's Avatar
wt200999 wt200999 is online now
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
They have been working great here so far
The limit switch jumper isn't missing from the backward limit pin is it?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 16-01-2009, 06:53
KevinReid's Avatar
KevinReid KevinReid is offline
FRC #2609 (Beaver worX)
KevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to behold
Our Jaguars are working fine still, no issues. Seem more controlled at low speeds than Victors were.
Unread 16-01-2009, 11:56
We currently have 10 jaguars and have been running most of them for the last 2 months.
We had 1 jaguar that shipped without the PWM connector, and one that was missing a limit switch jumper. We RMAd the first one (painless) and added the jumper to the second. Other then those two manufacturing defects, we have had no failures.
Unread 17-01-2009, 16:49
FRC #1782
Re: just wondering
I asked because I've read that several people have had them burn out>
Unread 17-01-2009, 17:57
skidmarks skidmarks is offline
FRC #0957 (WATSON)
skidmarks is an unknown quantity at this point
Our team was running the benchtop setup, but one motor wasn't working right. It was reversed, as indicated by the LED on the Jaguar. When we swapped out that Jaguar, it worked fine. Then, later in testing (still with the benchtop setup), both motors stopped responding and we smelled burning. Both Jaguars were destroyed at about the same time, after running fine for a little while. For now, we are using Victors.
Unread 17-01-2009, 18:13
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
we just got ours on our new robot and they work fine.....although thier alot bigger
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 20-01-2009, 15:19
utlinebacker's Avatar
utlinebacker utlinebacker is offline
AKA: Scott Emley
no team (Texas Instruments)
Team Role: Marketing
utlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud of
This seemed like a good place to post this:
Make sure you start here: http://www.luminarymicro.com/jaguar
If you are still stumped, remember that you can contact our applications engineers (directly) at support@luminarymicro.com. Make sure you provide our engineers as much information as possible to be able to support you.
Regards,
Scott
Scott Emley
Marketing Manager
Texas Instruments
Unread 22-01-2009, 22:51
feilmeier feilmeier is offline
FRC #0585
feilmeier will become famous soon enoughfeilmeier will become famous soon enough
Our team wired the jaguar backwards, and naturally a puff of smoke was emmitted. My question was, will replacing the 3300 microfarad capacitor fix it, or did many circuits in the jaguar get burned out
Unread 28-03-2009, 23:49
Jablonski@1250's Avatar
Jablonski@1250 Jablonski@1250 is offline
AKA: Greg Jablonski
FRC #1250 (Gatorbots)
Jablonski@1250 has a spectacular aura aboutJablonski@1250 has a spectacular aura about
Re: just wondering
Ours failed at Cleveland- we we pulling x amount of current through them and for some reason they would shut down. The Luminary Microsystems rep couldn't offer an explanation why. This happened twice, so we pulled them and replaced them with victors and have not had a issue since.
How many teams had router problems? darkember Technical Discussion 8 31-01-2009 21:22
How many people like bumpers? diesel Rules/Strategy 53 24-01-2008 15:30
How many people like bumbers? diesel Rules/Strategy 3 18-01-2008 17:34
How many people get on CD at school... Ashley Christine Chit-Chat 37 21-06-2005 13:14
how many of u actually used the stacker if u had one? HolyMasamune General Forum 21 14-04-2003 13:12
