Go to Post Let's see some love for these fine people. Let's give it up for the refs. - Andy Baker [more]
Unread 17-01-2009, 14:20
GunfighterJ's Avatar
GunfighterJ GunfighterJ is offline
AKA: Joseph
FRC #2450 (RaiderBots)
GunfighterJ is an unknown quantity at this point
Question Voltage Sensor
How do you wire the voltage sensor to the cRIO analog sensor input?
Unread 17-01-2009, 15:40
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Voltage Sensor
Voltage sensor? If you are talking about how to setup/activate the battery voltage monitoring capabilities built into the Analog breakout board then the information you are looking for is on page 21 and 22 of Chapter 3 of the Control System Manual.
You will need to install a jumper on some of the pins of the Analog Breakout board connected to the module in Slot 1 of your cRIO.
Since it is CRITICAL that at least one person on your team and preferably all of your electrical and programming members read the documentation regarding the new control system I will not cite the exact procedure here.
If you have further questions after referencing the documentation I referred to then feel free to ask them here.
Unread 18-01-2009, 12:39
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
Re: Voltage Sensor
The manuals says to:
Place jumper on the top 2 pins for
connecting battery voltage to AI8 or
jumper on the bottom 2 pins for
connecting AI8 from the 3x8 connector
What does that mean? How will the result differ if I've got it connected to the top 2 vs the bottom 2?
Unread 18-01-2009, 13:09
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Voltage Sensor
Analog Input #8 in Slot 1 is the middle pin of the 3-pin header on the Analog Breakout. When the jumper is connected to the top 2 pins, battery voltage is connected to Analog Input #8. When the jumper is connected to the bottom 2 pins, the 8th input on the 3x8 pin field is connected to Analog Input #8 in case you've get an 8th analog voltage to read. With no jumper installed, Analog Input #8 is floating and indeterminate.
Per the rules, the jumper MUST be installed for battery voltage monitoring on Analog Input #8 of Slot 1.
Russ
Unread 18-01-2009, 14:34
Re: Voltage Sensor
If you use the Analog Bumper in Slot 2, you would typically jumper the lower two pins on that, because you don't need to be reading the battery voltage in two different places.
DC Voltage indicator Don Wright General Forum 5 09-09-2005 07:52
Voltage sensor Andrew Blair Electrical 7 28-07-2005 08:42
OI Voltage JAH Electrical 7 12-11-2004 20:01
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
Voltage Byte -> True Voltage Ulibrium Technical Discussion 11 01-03-2002 08:55
